Dot 3 Dot 4 question fluids
Old Dec 21, 2008 | 09:56 AM
KTVette's Avatar
KTVette
Default Dot 3 Dot 4 question fluids
Ok, so I wasn't paying attention when I put my Super Dot 4 brake and clutch fluid in my brake reservoir. Brakes call for the Dot 3. Will this be an issue, added about an ounce.
Thanks in advance for any help you experts out there can provide.
Old Dec 21, 2008 | 11:16 AM
TEXHAWK0's Avatar
TEXHAWK0
Did you read the label on the brake fluid you used?
Doesn't it say that the fluids are compatible?
Old Dec 21, 2008 | 11:26 AM
vertC6's Avatar
vertC6
Dot 4 is fine, it has a higher boiling point
Old Dec 21, 2008 | 05:14 PM
KTVette's Avatar
KTVette
Default Thanks, and...
GM doesn't put that on the label. It's the part # for the clutch and says "Don't drink it!" and a whole bunch of stuff as to what will happen if you do.
Old Dec 21, 2008 | 05:17 PM
KTVette's Avatar
KTVette
Thanks BJ.
To Dot 3 Dot 4 question fluids
