Mgw 08c6
Old Dec 21, 2008 | 12:16 PM
BUSMAN C6's Avatar
BUSMAN C6
Default Mgw 08c6
Anyone here have MGW shifter in 08/09 C6 have any comments on it?Any real difference from stock?
And Im not a dragster so I assume I should get the 30% shifter?
Old Dec 21, 2008 | 12:18 PM
mittens's Avatar
mittens
have one in my 06. LOVE it.
Old Dec 21, 2008 | 12:32 PM
BUSMAN C6's Avatar
BUSMAN C6
Ive heard the raves in 05 to 07 but 08 has tighter stock shifter.
Old Dec 21, 2008 | 03:23 PM
BUSMAN C6's Avatar
BUSMAN C6
Old Dec 21, 2008 | 03:51 PM
nwc6's Avatar
nwc6
Installed the 30% in my 08 last spring. Even though the 08 shifter was improved, the MGW is a vast improvement over stock. I would have the occasional 2-5 shift instead of 2-3..Not a single missed shift in 5000 miles with the MGW..If you use the stock ****, (I did), you may have to address **** rattle, but easy to do.
Old Dec 21, 2008 | 03:55 PM
BUSMAN C6's Avatar
BUSMAN C6
Thanks I do like the stock ****, whats the fix for rattle?
Old Dec 21, 2008 | 04:29 PM
FUNTRUN's Avatar
FUNTRUN
Default 08 mgw SHIFTER
This is one of the best mods you can do to your car. I put one in my 08,with the stock ****, and have had no probs with rattles. This thing is the best. GM should be buying these things and using them as the OEM parts.
Old Dec 21, 2008 | 04:34 PM
BUSMAN C6's Avatar
BUSMAN C6
Thanks my Xmas gift
Old Dec 21, 2008 | 04:57 PM
nwc6's Avatar
nwc6
I just used a dab of the RTV compound that comes with the shifter on the shaft before I put the **** on. One forum member had to use some double sided tape on his to take up the slack on the stock ****.
Old Dec 21, 2008 | 08:52 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Ditching the stock ****.
http://forums.corvetteforum.com/c6-z...post1567423035
Old Dec 21, 2008 | 09:21 PM
BUSMAN C6's Avatar
BUSMAN C6
Originally Posted by '06 Quicksilver Z06
Thanks for post read most of your thread,maybe I will try one of his shifters.
Old Dec 21, 2008 | 09:29 PM
TLK's Avatar
TLK
St. Jude Donor '09-'11
Put it where? On the flat part? Mine rattles horribly.
Old Dec 21, 2008 | 09:46 PM
311badger's Avatar
311badger
Installed the 30% in my 08 last spring. Even though the 08 shifter was improved, the MGW is a vast improvement over stock. I would have the occiasional 2-5 shift instead of 2-3..Not a single missed shift in 5000 miles with the MGW..If you use the stock ****, (I did), you may have to address **** rattle, but easy to do.
Night and Day difference
Old Dec 21, 2008 | 10:28 PM
nwc6's Avatar
nwc6
http://forums.corvetteforum.com/c6-c...lly-fixed.html
Old Dec 21, 2008 | 10:53 PM
HorsePower Junkie's Avatar
HorsePower Junkie
St. Jude Donor '20-'21-'22-'23
Old Dec 21, 2008 | 11:05 PM
TLK's Avatar
TLK
Hmm.. that hasn't worked for me. I've tried tape on various parts of the shaft, but it is impossible to get the **** on with the tape in place. And it gets badly chewed up.
Old Dec 22, 2008 | 12:44 AM
wildo's Avatar
wildo
I installed one in mine in July, I love it no rattles or problems
easy to install.
Old Dec 22, 2008 | 06:27 AM
dfinke23's Avatar
dfinke23
Mine was rattle free over the summer, but when the temps dropped it started making noise. Mgw needs to use larger diameter O-rings or come up with a thin rubber bushing that goes over the shaft and under the ****. I think I might try to cut the pinke off a rubber glove and slip it over the shaft. Another possible fix is to come up with a threaded shaft in a diameter that the plastic OEM **** might thread on to.
To Mgw 08c6
