Help with strange question
First, with the car in normal mode (magic button untouched) there has never been an issue, can sometimes do small burnout/lose traction if accelerate hard enough.
I have pressed the traction control button off several times to play, with no trouble, normal burn outs, normal response.
The problem?/question is this, twice now I have pressed the button once for traction control off to mess around and when doing a high rpm burnout/spinning uturn the clutch will not rebound. It stays just off the floor, the car acts normal (ie continues to spin), but I have never seen this before. If I go to repress to shift it comes back to normal, or if I depress to cancel the burn, it returns to normal.
Anyone have any ideas? Is this normal--I would think not. It would seem to me the clutch was slipping, but normally that would still give you pedal rebound, just dead feel, right? Also wouldn't continue the power to the wheels. And bu the way, the car has never been tracked and has <5000 miles. Just like to drive her hard, but definately haven't abused the clutch--just messed around 10-20 times over its life so far.
Any comments would be helpful.
First, isn't it supposed to be honey colored and clean?
Second how do I change it?
THanks.
Thanks again to the forum!!!
