Question and wiring diagram needed
Old Dec 26, 2008 | 06:30 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Default Question and wiring diagram needed
I am needing a wiring diagram for an 08 Vert' ignition/start system.
Will the C6 start and run without the Onstar antenna and radio (Bose system)?
Old Dec 26, 2008 | 07:02 PM
GMautotech's Avatar
GMautotech
I honestly don't know if it will start without the radio.
Old Dec 27, 2008 | 10:54 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Thanks for the diagram. Can someone unplug their radio and see if their car will start? I really kidding unless someone would. It may clear up my start problem. I will run down a factory radio to plug in and see as well.
Old Dec 27, 2008 | 02:45 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
By "start", do you mean actually fire or are you simply talking about cranking?
Old Dec 27, 2008 | 09:57 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Right now I would be happy to here it turn over, actual fire and run can come later. I have traveled to Orlando where the car is and will be with it Monday so I will be able to better describe the symptoms. As of now when the car recognizes the fob and you push the start button it just clunks for a milisec and all systems shut down. I can unhook the battery and reconnect all accessories come back on till you push the start button again.
Old Dec 28, 2008 | 12:27 AM
KenHorse's Avatar
KenHorse
Assuming you've checked the battery and it's fine, it sounds like the BCM's anti-theft circuit is doing its job.
To Question and wiring diagram needed
