Battery Tender using CTEK ?
Old Dec 28, 2008 | 09:56 AM
RHFD122's Avatar
RHFD122
Default Battery Tender using CTEK ?
I just ordred the CTEK battery tender unit as I do not have a garage and must leave my vette in the driveway under a car cover when I'm nor driving it Mon - Friday. I need a unit that is small that is easily intalled under the hood as I live on Long Island, New York. Can anyone comment their expierence using the CTEK ? Thanks
Check out the specs:
http://www.customcorvetteaccessories...rycharger.html
I appreciate any feed back that you can share.
Old Dec 28, 2008 | 11:30 AM
C6 BigSky's Avatar
C6 BigSky
4th Gear
I use the CTEK battery tender (second winter here in cold Montana). It works well. Might be a tight fit to install under the hood.
Old Dec 28, 2008 | 11:48 PM
RHFD122's Avatar
RHFD122
How do you hook it up, temporary using clips or accessory plug, or an other method?
Thanks for your feed back.
Old Dec 29, 2008 | 12:29 AM
Mike's LS3's Avatar
Mike's LS3
My vette is garaged, but the Ctek 3300 works great. If my car sits more than two weeks, I will hook it up using the battery clips for a charge the night before. Sometimes it will reach a full charge in 30 minutes and then go into the maintenance mode. I do not have any battery drain issues, but I like to keep the battery cells healthy. The charger is small enough to close the hood and run the cord down under the car, however when charging a battery, ventilation is recommended for the gases to escape. You might want to look into the necessary precautions when charging a battery.
Old Dec 29, 2008 | 10:50 AM
Wingrider's Avatar
Wingrider
As far as ventilation is concerned, I believe that was an issue before sealed batteries. Today, with a sealed battery, i don't think that is really an issue.
Old Dec 29, 2008 | 06:07 PM
RICHY2001's Avatar
RICHY2001
I used an indoor Deltran unit located under the hood with the car covered outdoors for several years with no problems.
Just unplug and drive away.
To Battery Tender using CTEK ?
