Engine vacuum
Old Dec 29, 2008 | 09:19 AM
bearnest's Avatar
bearnest
Default Engine vacuum
Does anybody know a easy way to get to vacuum port on back of engine?? I believe there are two back there,one is used for brake booster,and not sure about the other one.thanks guy's and happy new years
Old Dec 29, 2008 | 10:48 AM
haljensen's Avatar
haljensen
There is no easy way to get to the vacuum port. The one you need is the smaller diameter with the "T" tab on the end, the larger diameter right angle fitting is the brake booster line. Just break off the "T" and slide the hose over the fitting.
Pictures are from my '05 LS2.
