LS-2 Throttle body spacer
Old Dec 29, 2008 | 08:57 PM
MR.G.'s Avatar
MR.G.
Default LS-2 Throttle body spacer
I saw an ad in a car magazine displaying performance parts. One in particular was a throttle body spacer claiming to add 2-3 hp. As I recall it wasn't too expensive. I thought it was cheap H.P. Do these work and upon what principle?
Thanks,
MR.G.
P.S. Happy New Year Everyone!!
Old Dec 29, 2008 | 09:25 PM
NormWild's Avatar
NormWild
Save your cash, they tend to warp causing sealing issues and hp gains are nominal.
Old Dec 29, 2008 | 09:53 PM
JayplaySS2's Avatar
JayplaySS2
I run one with no issues but be your own judge. This mod seems to go either way. Works fine for me though. Do all of the CAI (CAI/Vararam, ported tb, spacer) mods if you decide to get one.
Old Dec 29, 2008 | 11:17 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
First, 2-3 HP is well within the error band of most any dyno when you're up in the 300+HP range, so it doesn't take much for a snake oil salesman to pick the "best" of several dyno runs to support an advertising claim.
Second, the original idea of throttle spacers was to effectively increase the length of (relatively short) runners from a carb to a cylinder, and to possibly reduce heat transfer from the intake manifold to the carb (hard to believe this does anything useful on a fully warmed-up carb'd engine). In the LSx application, the throttle body is miles away from the cylinders -- I can't see how the additional few mm of length added by the spacer could have _any_ measurable effect on HP. As as to heat, the throttle body is already mounted way out front on a low heat-transfer plastic manifold, so that's a non-issue in this application.
Finally, if your SOTP meter is sensitive enough to detect a <1% change in HP, your tail feathers are *far* more highly calibrated than mine.
$0.02 deposited, pot stirred
HTH,
Mark
Old Dec 30, 2008 | 12:03 AM
jrpedraza's Avatar
jrpedraza
In installed mine because it came with the Vararam, otherwise I probably would not have installed it. I can't say there is a measurable gain but since it came with the CAI I installed it.
Old Dec 30, 2008 | 06:53 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Old Dec 30, 2008 | 07:10 AM
SpinMonster's Avatar
SpinMonster
Thanks,
MR.G.
The spacer increases plenum volume which does make some minor HP increases but every HP counts. Increasing plenum volume is one thing porting does on an intake manifold (small increase) and does work. The not-worth-it guys dont subscribe to a HP here and aHP there and thus dont get the total gains that one can get from all the few HP gains.
UD pulley 9rwhp
Ported TB 3-4
porting an intake manifold: 10-15
Aluminum flywheel: 9-12hp
exhaust cuttouts (5-6HP...stock car)
electric water pump: 6rwhp
roller rockers:10-12HP
In the end people just raised the BS flag when Tony Mamo dyno'ed 490rwhp with AFR 205 heads and a 224 cam. Other guys skipping the not-worth-it mods got 460rwhp many times over. now you know why.
The down side to increasing plenum volume is a loss of throttle response.
a search produced many papers related to TQ and the like such as this one:
http://www.sae.org/technical/papers/2008-01-3007
Old Dec 30, 2008 | 08:06 AM
LostAngel's Avatar
LostAngel
UD pulley 9rwhp
Ported TB 3-4
I always enjoy reading your posts!
Old Dec 30, 2008 | 09:16 AM
SpinMonster
Thanks.
Old Dec 30, 2008 | 10:08 AM
HawaiiC6's Avatar
HawaiiC6
Spin you are the best especially in explaining things. You really are what makes this board the best.
Happy New Years everyone.
On the post about the TB spacer warping, where did you get that information from? I have been running mine for about a year and have had no problems. I would say those that have had any warpage is from overtighting the TB bolts and not tighting the bolts evenly.
To my knowledge the only warpage was on the old Vararam CAIs which they corrected.
Old Dec 30, 2008 | 10:51 AM
JayplaySS2's Avatar
JayplaySS2
UD pulley 9rwhp
Ported TB 3-4
Great post Spin, as usual. Its great that you take the time to explain your point where other guys (myself included) just throw thier opionons most of the time.
Old Dec 30, 2008 | 11:17 AM
MR.G.'s Avatar
MR.G.
Default T.B. Spacer
Thanks to Spin and others for such a good explanations. I do have a PPTB but I don't want to sacrafice any bottom end. Two questions have been spawned as a result. First, on the Throttle Body there is a honey comb bisquit on it similiar to those on the front of some MAS air flow meters. I PP the throttle body should that honeycomb bisquit have been removed? It seems restrictive. Second, what are exhaust cut-outs? I have an 05 Automatic 2:73 gears. Where or how can I acquire one for her?
Thanks,
MR.G.
To LS-2 Throttle body spacer
