Vert top doesn't go up
Old Jan 1, 2009 | 11:47 AM
C4 Racer's Avatar
C4 Racer
Default Vert top doesn't go up
Repairing a 07 C6 convertible
Top doesn't go up.
Both Air bags have deployed and driver door off car. do any of these thinks contribute to top no going up, also the Pass. door window doesn't go up either. Is this because of drivers door not installed?
Old Jan 1, 2009 | 12:26 PM
vetteride4u's Avatar
vetteride4u
Default top
I know that the door windows need to go down to get the top to go up or down! Probably an issue with the door not being on.
Old Jan 1, 2009 | 12:39 PM
C4 Racer's Avatar
C4 Racer
So it knows when the windows are down to activate the top, Then the loop of the drivers door not being there must be preventing the top from moving. makes sens.
Old Jan 1, 2009 | 04:31 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
When you get both windows operating, they have to be indexed before the top will operate. Indexing is simply running the window all the way up, with the door closed, until it stops, but continue to hold the button up for ~5 seconds. You will hear an audible click.
Old Jan 1, 2009 | 10:21 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
There is also a switch located on the bracket by the hinge on the trunk. Make sure it is plugged in or else nothing will work.
To Vert top doesn't go up
