Brake pad install..
Old Jan 3, 2009 | 02:56 PM
MLCZ51's Avatar
MLCZ51
Default Brake pad install..
Time to change the pads on my 06 z-51, i have the hawk pads and i need to know what wrench do i need to take the bolts off the calibers, i have not done this in years. I know i need a c-clap and what else...thanks guys..i did my 86 pace car and it was simple..THE PADS ARE STILL ABOUT 35%, JUST WANT TO CHANGE BEFORE THEY GET WORN DOWN TO LOW...
Old Jan 3, 2009 | 03:22 PM
timd38's Avatar
timd38
I believe it is 14mm and the caliper comes off. On the front you don't need to take both bolts off, just one and loosen the other.
Old Jan 3, 2009 | 06:40 PM
c6_rob's Avatar
c6_rob
take the bottom out, loosen the top, hinge up the caliper, push piston in (take lid off res.), and install new pads
Old Jan 3, 2009 | 10:26 PM
MLCZ51's Avatar
MLCZ51
Default thanks
you guys are the best......
To Brake pad install..
