Fuel Rail replacement
Old Jan 3, 2009 | 08:35 PM
C6_blackhawk's Avatar
C6_blackhawk
Default Fuel Rail replacement
I need to replace my leaking fuel rail on my LS2. Is the drivers and passengers side all one piece or are they 2 different pieces? Also, any advice on removing and installing one would be great! Thanks!!
Old Jan 3, 2009 | 08:46 PM
sea six's Avatar
sea six
It is a one piece unit. It is very easy process. Need a tool to disconnect the fuel line. There are several aftermarket setups that add a little class if you want to do something a little different.
Old Jan 3, 2009 | 08:58 PM
C6_blackhawk
Thanks for the advice. Sounds like I'll be doing this myself.
Where would one find said "tool" to disconnected the fuel line. Is it a GM tool or a standard automotive tool that can be rented from autozone?
Old Jan 3, 2009 | 09:03 PM
johnodrake's Avatar
johnodrake
Moderator
They are a couple of bucks from autozone.
Old Jan 3, 2009 | 09:05 PM
C6_blackhawk
Awesome! Thanks!!
To Fuel Rail replacement
