Tps
Old Jan 5, 2009 | 12:05 PM
1st time owner's Avatar
1st time owner
Default Tps
Does anyone know how accurate the TPS are,,I have what I think is a pretty good tire gauge but I sometimes get up to a 2lb difference between the sensor and the gauge. 08 C-6 thanks
Old Jan 5, 2009 | 12:46 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've used two different digital guages and both agree with the onboard pressure indication in my '07. They also worked with my '99.
Old Jan 5, 2009 | 05:19 PM
AintQik's Avatar
AintQik
I've seen a 1~2 pound difference on the gauge I use. No big deal to me, but I'm just a former Philly guy stuck out in the boondocks. I know yous can be pretty uptight
Old Jan 5, 2009 | 05:47 PM
dennis50nj's Avatar
dennis50nj
Old Jan 5, 2009 | 06:40 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I use an analog gauge which I set pressures with. The TPS reads about 1-2 psi less. Could be that my gauge needs calibrating, but I suspect that the TPS is less accurate.
Old Jan 6, 2009 | 12:29 AM
siffert's Avatar
siffert
I have an analog and a digital that talks to me and they always read a 2 psi difference too.
Old Jan 6, 2009 | 12:47 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I have a very nice gauge that is also 1-2 pounds different than the TPS.
San
Old Jan 6, 2009 | 08:39 PM
Wrenchen's Avatar
Wrenchen
They don't seem to account for altitude. Other than that they seem to be correct.
Old Jan 6, 2009 | 09:33 PM
miwung's Avatar
miwung
I switched to nitro fill and got a really good gauge and I always read 30 pounds all the way around. TPS reads from 28 to 30 pounds usually.
Old Jan 6, 2009 | 09:38 PM
cadguymark's Avatar
cadguymark
what exactly are you saying? The mass of air in the tire dos not change as you change elevation, neither does the volume of the tire, so the pressure remains the same, the only thing remaining that can change the pressure is temperature change, which likely goes up due to the heat of rolling resistance, the altitude change just does not figure into it directly unless there is a large temperature change accompaning the altitude change
To Tps
