A6 trans downshift?
Old Jan 6, 2009 | 07:25 AM
WIPLASH's Avatar
WIPLASH
Default A6 trans downshift?
My trans is downshifting hard i had the trans tune a while ago but it just started doing it. Any suggestions?
Old Jan 6, 2009 | 08:42 AM
Larry R. Quinn's Avatar
Larry R. Quinn
When your A6 transmission was tuned , I suspect that the shifting response time was decreased and the clamping pressure was increased . At higher RPM's , when downshifting , it should feel hard or more solid . This may be what you are experiencing .
Old Jan 6, 2009 | 07:52 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Are you seeing the Check Engine light at all? The reason I ask is that believe it or not, the transmission will shift noticeably harder if your MAF sensor isn't working properly.
I did a VE tune on my car last week (which requires you to disable the MAF) and what ends up happening is the PCM determines something is wrong and sets the transmission line pressure to full, basically in an attempt to alert the driver that something is wrong.
Who did the tune by the way?
Christopher
Old Jan 6, 2009 | 09:21 PM
siffert's Avatar
siffert
I thought you wanted WIPLASH with your A6? Well, apparently you got it. I can only guess who is the tuner
All joking? aside, can you describe better what your problem is? Is this "hard" downshifting in paddle mode or while in D or S auto mode? Or are you having hard downshifts when you stomp on the throttle while cruising and "kick down" one or more gears while in D or S mode?
Old Jan 6, 2009 | 10:14 PM
C5pilot's Avatar
C5pilot
Suggestion: Be VERY specific as to what is happening. Start from the beginning.
Old Jan 7, 2009 | 08:16 AM
WIPLASH's Avatar
WIPLASH
Its when coming to a complete stop regular driving there is a clunking noise when it downshifts from 3rd to 2nd & 2nd to 1st
Old Jan 7, 2009 | 09:32 AM
jmt1669's Avatar
jmt1669
St. Jude Donor '11
Are you sure it's coming from the trans? Have you checked the axle nuts?
Old Jan 7, 2009 | 01:23 PM
MarylandSpeed's Avatar
0MarylandSpeed
Former Vendor
Maybe unplug the battery and let it relearn?
Old Jan 7, 2009 | 02:06 PM
siffert's Avatar
siffert
Relearn what? Not to clunk on downshifts?
btw-recently ordered a FAST intake from you, Jen is a gem of an employeee of yours-great service...as usual.
Old Jan 7, 2009 | 07:38 PM
C5pilot's Avatar
C5pilot
If it was happening all along I'd say the tuner may have disabled TM for Closed Throttle Downshifts and/or increased line pressure too much. If you don't have access to tuning software, simply call the tuner and ask. But clunking while slowing could be another part of the drivetrain too.
Any good tuner would invest the time to help out a past customer. He/she should WANT to know if something is happening after a custom tune.
Remember, you have an adaptive transmission, so over time it makes adjustments of it's own to compensate for wear and tear. But I wouldn't waste anymore time, if you can't visit your tuner, at least call.
Old Jan 7, 2009 | 09:54 PM
knkali's Avatar
knkali
If it was fine for some time after the tune then look for something else other than the trans. I noticed in the avatar that the car is lowered. If so, you might want to look for something hitting like exhaust or ?? when the car is flexing on shifts. Just a thought.
Old Jan 8, 2009 | 12:44 AM
C5pilot's Avatar
C5pilot
Universal joints may knock if the drivetrain alignment is off. But it would feel more like a bouncing than a clunk. You'd get the clunk when you put it into gear and a wobble on deceleration.
To A6 trans downshift?
