Generally speaking the clowns behind the counter at Autozone are clueless. My experience has been that they can look up a part number on the computer correctly about 4 out of every 10 attempts! I'd do my own research before taking any recommendation from some guy making $7.50 an hour at "The Zone" !
recommended STP oil filters for my '07. So my first oil change got an STP filter. Did I listen to the right people?
No. STP filters are cheap junk. Best off the shelf at AZ would be the M1 filter (top quality synthetic). Wix is good too for a paper filter (sold at NAPA). Amsoil is the best, IMO. The new AC/Delco Ultraguard used on the ZR1 could be considered one of the best too, but I'm not sure if they make a version for the LS2 yet.
I switched to WIX after I had problems with the gasket on an ACDelco filter leaking. WIX is a good filter and I have never had a gasket leak.
I think for awhile, Delco (and maybe others) tried to make the threaded end plate thinner and it would deform and eventually leak under stress.
I don't frequent Auto Zone. The one nearest, me you need to speak mexican for anyone to understand what you want, then, they still don't understand what you want.
