Rotor and pad suggestions
Old Jan 7, 2009 | 04:36 PM
Corvette08dreamin's Avatar
Corvette08dreamin
Default Rotor and pad suggestions
If I decide NOT to go with Z06 big brakes behind my new wheels, can anyone tell me what are some of the better rotors and pads on the market to upgrade my base C6 rotors? I would like to go with drilled and/or slotted "zinc washed" rotors. Two-piece rotors are not a must, but would like to stay around the $500 range for the set.
Old Jan 7, 2009 | 09:18 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I have DBA rotors with my Z06 brakes, they retail for 624 for the regular ones from tire rack. I could get them for you for a little less though.
Old Jan 7, 2009 | 10:42 PM
Silverton's Avatar
Silverton
Take a look at these:
http://performanceafx.com/store/inde...75867f8cbf5a6e
Old Jan 8, 2009 | 12:07 AM
OZ51's Avatar
OZ51
Why are you upgrading? Your intended use of the car may impact your decision. If you're just looking for improved street performance and appearance, you'd probably stay close to your budget picking up a Z-51 upgrade through Gene Culley... uses stock calipers, adds caliper brackets and rotors. Stock C5Z pads get good reviews, reasonably priced and available through the same source.
Good Luck!
Old Jan 8, 2009 | 08:38 AM
LEAVINU's Avatar
LEAVINU
I went with Carbotech pads and Z51 upgraded rotors from my base brakes. Amazing stopping power now. Also threw in some SS lines to firm it up.
I do alot of spirited driving, mtn runs, autox, and some track events.
I have killed the stock Z51 rotors now and will be moving to the AP racing rotors that Silverton linked to.
Old Jan 8, 2009 | 11:54 AM
Corvette08dreamin
Thanks, I will check out these pads. I like the above mentioned rotors as well. However, I don't do a lot of spirited driving. Only 2K miles on my car, so I am doing the upgrades more for cosmetics, but to have the performance too..lol. I kind of like the drilled and slotted rotors, so I may lean more towards the Baer 2-peice rotors.
Old Jan 8, 2009 | 12:18 PM
LEAVINU's Avatar
LEAVINU
If thats the case I wouldnt suggest the carbotechs then. They are GREAT pads in stopping power but dust like crazy.
Go with some stock or ceramic pads if the "look" is what you are looking for mostly.
Old Jan 8, 2009 | 09:59 PM
CMY SIX's Avatar
CMY SIX
DBA 4000 series slotted rotors, very high quality! autoanything.com free shipping
To Rotor and pad suggestions
