What Mufflers For LS3?
Old Jan 8, 2009 | 09:42 PM
2002ls1z's Avatar
2002ls1z
Default What Mufflers For LS3?
My LS3 is way too quiet for my tastes and there's no way in hell i'm shelling out big bucks for a cat-back system. I'd like to weld in aftermarket mufflers in place of the stock ones. I want it to be noticeably louder than stock, but want to keep drone to a minimum on the highway. What do you guys reccommend? Links to videos and part numbers are great!
Old Jan 8, 2009 | 09:57 PM
SL33PER's Avatar
SL33PER
I am very happy with my ZO6 exhaust and M2W switch. Best of both worlds, plus you can pick a set up pretty cheap.
Old Jan 8, 2009 | 09:58 PM
johnodrake's Avatar
johnodrake
Moderator
Look for Z06 take-offs.
Old Jan 8, 2009 | 10:04 PM
Top Down Z51's Avatar
Top Down Z51
Corsa is always a great choice for that deep sound without drone. Good luck on your hunt!!
Old Jan 9, 2009 | 12:28 AM
silvervette05's Avatar
silvervette05
i did magnaflow bullet weld ins 14 inch long 2 1/2 inch in and outs..and while it sounds dang good it has a bad drone when i get on the highway..i'd say try and find a set of z06 take offs..
Old Jan 9, 2009 | 04:12 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Z06 Mufflers
Old Jan 9, 2009 | 06:49 AM
mikeci's Avatar
mikeci
beware of other opinions when it comes to exhaust systems everybody's ear is different. there many reasons for the 1250-1600 rpm drone. vert or coupe, any other mods, etc. I can tell you anytime you divert from stock you will pick up some drone to so much you get a migraine. even the npp has it when its open imho. I have not tested all the different ones so maybe there is one that does not drone. if that is the case then its going to be pricey.
I recommend that you find other vette owners and ride in their cars before you lay out the cash. do the homework you will be much happier then doing the mufflers a couple of times till you get it right. I have found most owners will be more than happy to let you take a ride and offer so much advice your head will explode. that's what the brotherhood is all about.
good luck,
Mike
Old Jan 9, 2009 | 10:04 AM
haljensen's Avatar
haljensen
I had an '05 C6 Z51 Manual 6spd w/#14336 Magnaflow mufflers welded in, great sound BUT lots of drone.
I now have an '08 C6 Z51 A6 w/NPP and Sunset Orange Creations switch, great sound open AND NO DRONE @ Hiway speeds cause I can close the flaps.
Old Jan 9, 2009 | 12:13 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
A set of NPP or Z06 mufflers would be great if you can find them at a decent price. I have used Magnaflow in the past and is a great muffler. The sound is deep and no rasp. Like Hal stated, there is drone on the highway and that will be the case with most aftermarket mufflers. I have the NPP and on the highway, there is drone when I am 6th gear. The NPP mufflers are great since you can control what state they are in.
Old Jan 9, 2009 | 06:11 PM
dkrhardy's Avatar
dkrhardy
I did Magnaflow, loved the sound but the drone was waaaay too much. I also did the Z06 with M2W and love it. Look around, got mine for $312 DELIVERED!
Old Jan 10, 2009 | 08:27 AM
hansesm's Avatar
hansesm
Default Corsa Sports
The only way to go. Loud when you get on it, but quiet at the 70 MPH cruise. Best of both worlds
Old Jan 10, 2009 | 01:11 PM
cmonkey713's Avatar
cmonkey713
good luck,
Mike
This is what I always recommend. This advise is completely correct. Save yourself an expensive mistake
Old Jan 10, 2009 | 01:19 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Good choice? Deep sound? Corsa's? I don't think so. I bought Corsa's b/c everyone on this forum is in love w/them. The aren't deep, they're high pitched. They aren't cheap (What the OP is looking for), at $1200+, and they weigh....WAY too much. Not a good choice.
OP, you're on the right track, building your own system. Only way to go, and way, WAY cheaper (with better results). Good luck and I'm not giving advice except listen before you buy.
To What Mufflers For LS3?
