Headers and Ported Fast 90 OR 4.10 gears?
4.10 Gears driving in slow moving traffic is more pleasant. All you need
to do is let the clutch out and the car will roll in traffic at 600 rpm and
the clutch will last much longer and less drive train trauma as opposed to a 3.42.
Headers and the FAST is likely the better way to go but I wouldnt do any series of mods without gears in the end FI included. It makes sense to strengthen before adding power.
4.10's has been my favorite mod on all my vettes.
I would do them in this order:
1-4.10 gears...be sure to gear for the application. If you plan on faster than 128 trap speeds get 3.90's.
2-headers/FAST-tune
3-Add power.
I would get the 4.10's... FEEL THE CAR WAKE UP ON THE STREETS!!!
If its the oem runflats you got, then I think its the headers and fast for you.
Dennis50NJ still has the stock heads and cam and had the 4 tenths gain with the car so the H/C requirement to justify the FAST is also not based on facts.
Lasty you have it completely backwards. A cam does nothing under 4500rpm while the FAST starts m aking more power from 3000 up. I dont know what dyno sheet you looked at but the FAST is definitley not a 6k rpm mod. Your post is filled with misinfo.
In this dyno thre gains were minimal at 2500 and 6500rpm but still a few HP while the midband gains were a staggering 35rwtq+ in the 3500-5500 range.
In this dyno the peak power was also 27/33 at peak with similar gains under the curve again showing 3000-6500 as strong justifiable amounts and nothing like your 6k+ only power misinfo suggests. In fact saying the gains are only over 6k is pretty.....(fill in the word).
4.10's slow down the rate of rotation and let you hook sooner than 3.42's since the 3.42's are at a higher rate of rotation. It would break loose easier though but hook faster. Gears help you hook. Guys that dont have them dont know that, and always go by the myth you typed.
Guys that have really fast cars know you gear for the intended trap speed and stop adding power when you cant get it to the ground since power spins tires, not gears. So if you add 4.10's and have too much wheel spin, youre done. On the street your car is rarely over 2500rpm daily driving and light to light. The gears help exactly there and you feel it all the time. A H/C package makes more power past 4500rpm. Gears help the 1/8 mile big time and thats 0-100; kind of the type of driving you do on the street. Big HP helps the second 1/2 of the 1/4 mile or more like 100-135 in the 1/4.
About Joe_G
Signature
2005 LeMans Blue Convertible Z51 MZ6
Mods by Horsepower Sales - Pompano Beach 954-782-6700
3:90's, Spinmonster ported FAST 92, Vararam, A/R Headers w/cats, G5x3, Cometic .040 gaskets 450rwhp/408rwtq
Best times post-cam, pre-FAST 1/4 - 1.666, 11.540@121.39...1/8 - 1.666, 7.433@94.31 DA 1681
Best times post-cam, post-FAST 1/4 - 1.706, 11.414@124.48 DA 984...1/8 - 1.670, 7.354@95.10 DA 1200
About Joe_G
Signature
Joe's initial track test was on the 1/8 mile he reported 2mph and 2 tenths in the 1/8.
From his SPINfast install thread:
You can inscrease a car's power and get the mph with no increase in ET performance if you're not hooking but the mph is always an indicater of HP gains.
The thing you arent aware of because you dont have them is what happens to hook. Lets say youre at 3k rpm's in first gear with 3.42's. Thats maybe 30 mph spinning. The car then hooks when the car gets to the speed that the tires are roatating at: 30mph.
Now you get 4.10's and you're spinning at 3k rpmns which is reading 22mph on the speedo. Your car then hooks when the car hits the speed the tires are rotating at....22mph which happens before 30mph.
Being able to go WOT without breaking loose isnt a test of how fast a car is. How fast you get it to hook is with a higher power level.
My Dart (which I'm sure people are sick of hearing about) ran 6.13's with 700+rwhp and it pulled a wheelie out of the hole because it was only able to do 18mph in first gear. It was almost immediate to get that to hook yet it wouldnt hook with 4.88's.
One of two things can happen with a given power level. The car accelerates faster than the rpm's climb and then the tires and car match speed OR the car accelerates slower than the rpm's climb and then it never hits the speed of the tires because the tires are outaccelerating the car. 4.10's accelerate the car faster than the 3.42's can.
Anyone with a truck with 4 low gearing can tell you this: The car will always outaccelerate the rpms and it cant break the tires loose even though its like having 4x 4.10 gears. At redline the truck would be doing like 5-8mph.
About Joe_G
Signature
MPH was due to a single day's DA.
I am absolutely 100% behind doing whatever it takes to make your car go faster, but your numbers just aren't supporting your claims here.
Again, if I'm wrong (which I've known to be on hundreds of occasions) please post up some before and after numbers that make sense when accounting for the DA in addition to everything else.
OK................. I voted gears. Back on topic.
