supercharging c6 ?'s
Old Jan 19, 2009 | 03:06 AM
badass1g's Avatar
badass1g
Default supercharging c6 ?'s
will the stock clutch hold say 500 rwhp? what other things would i need to upgrade to keep the car reliable? i noticed a vortech supercharger kit used on ebay for 3200, what are they new? is that a decent kit? average install time?
its either sell the c6 and get a c6Z, srt 10, or supercharge my c6 ??? thanks everyone in advance
Old Jan 19, 2009 | 06:16 AM
Mr.Big's Avatar
Mr.Big
find ALL of your F.I. answers here...
http://forums.corvetteforum.com/c6-f...n-nitrous-123/
Old Jan 19, 2009 | 08:02 AM
EuroRod's Avatar
EuroRod
I have about 8k miles on my ProCharged 2005 and the stock clutch. Car makes 550 rwhp. So far I've had zero issues, but, I do not abuse the car. No track or strip days. No burnouts. The car does not hook in first or second gear. All of my "experiments in speed and distance" are usually on the interstate at higher speeds. But, on a cold day when the engine really makes horsepower, I get wheelspin at 80+mph!
Old Jan 19, 2009 | 09:33 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
You can't put a supercharger on a C6, its not possible.
Many guys including myself have the stock clutch. It seems to hold the power OK but you will likely experience the pedal to the floor syndrome if you flog it. On the street I don't get it but at the track or even the dyno I do.
Tires will be another thing you may want to invest in. Some good R compounds so you can use 1st and 2nd again.
Sticky tires will bring out the next weak spot, the diff. Hardened output shafts and perhaps a diff brace are good insurance.
The list goes on and on but it just depends on how far you want to go with it. Many are happy with just the blower kit.
Nice Avatar!
Old Jan 19, 2009 | 10:36 AM
greekc6's Avatar
greekc6
if ya keep it under 550-575 and dont drag race the hell out of it with drag radials, it should hold up for a while
Old Jan 19, 2009 | 11:03 AM
mirage2991's Avatar
mirage2991
I've seen it on there too...you will need bigger injectors and the boost a pump. the base kit sells for 4740 while the complete kit sells for 5200 from A&A corvettes.
Old Jan 19, 2009 | 01:12 PM
badass1g's Avatar
badass1g
can i just get it to about 500rwhp? dont really wanna push the reliability to much, besides 150 additional rwhp than i have now would feel like a rocket. atleast for a little bit. how do you turn the boost down on a SC?
Old Jan 19, 2009 | 01:19 PM
NYC6's Avatar
NYC6
Keep boost lower by using a larger pulley.I have an 06 A6 with LG Longtubes and a Vortech T trim. With a very conservative tune Im making 505/440 to the wheels. That power upgrade is night and day compared to before. Dont have many miles on it yet due to weather but it should hold up. Down the road I will add a 403 forged stroker and turn up the boost. Hopefully by then there will be a bullet proof A6 avaiable.
Old Jan 19, 2009 | 01:21 PM
TANGLVR's Avatar
TANGLVR
Base kit would get you about where you want. If you need to go down you can get a different sized pulley.
Old Jan 19, 2009 | 01:27 PM
CMY SIX's Avatar
CMY SIX
he's a "senior" member and does'nt know or has'nt read any of this before, in his "badass1g"
Old Jan 19, 2009 | 02:52 PM
danl72's Avatar
danl72
Old Jan 19, 2009 | 03:55 PM
Tzzird's Avatar
Tzzird
Base kit with no other mods is already more power than the stock runflats can handle (or any other non-r compound tire for that matter.
60-120 sprint is ridiculously fast. 0-60 will be hell with all the spinning you'll definitely encounter.
Old Jan 19, 2009 | 07:42 PM
huckleberrydude's Avatar
huckleberrydude
You won't need a boost a pump unless you push more boost. You will run out of fuel towards redline. You will need injectors. Still on stock clutch here for 14K. I drive the car pretty hard.
Old Jan 21, 2009 | 01:04 AM
alcgomez's Avatar
alcgomez
Nice Avatar!
Yes You Can ! www.Callawaycars.com
Old Jan 21, 2009 | 07:49 AM
EuroRod's Avatar
EuroRod
Easy decission. Get the Z06. Wish I had. Then, supercharge IT ! The brakes, suspension, wide wheels, everything, is already in place.
Old Jan 21, 2009 | 08:26 AM
patton's Avatar
patton
St. Jude Donor '09
To supercharging c6 ?'s
