Tire ?
Old Jan 31, 2009 | 12:00 AM
60pilot's Avatar
60pilot
St. Jude Donor '08
Default Tire ?
So I am about 26k miles and need to replace the tires so this here what i need some info from you guys?
1. Thoughts on the PS2 Zp's ( littlle more $$ I know)
2. Thoughts on the firestone wide oval's runflats? ( Much cheaper which worrries me a little about quality)
3. I still have some tread on the rears , the fronts are actually worse than than the back( ) so i would want to change the fronts first? wait and wear the backs some more? think there would be any issues with running 2 different tires on the front than the rear? I.e. different tread patterns? Think it would be ok! but just making sure?
Thanks!
Old Jan 31, 2009 | 10:38 AM
dkrhardy's Avatar
dkrhardy
Get ready, there are lots and lots of opinions with "facts" to back those opinions up with.
The Firestones seem to have a well deserved following because they ARE RF, smooth riding, more quiet, and lower cost. Name brand tire, shouldn't need to worry about quality.
I just changed from half worn GY's to Kumho Ecsta SPT (non RF) and they are more quiet and seem more smooth. But if my old GY's had a fresh balance how more smooth would they have been? So it is all subjective and biased by RF vs non RF opinions. I like the low cost and they do dampen bumps better than the GY's ever did. How much? Not much. It is NOT a night and day difference. I am happy I did the change. I also have a can of Fix-a-flat in my cubby. Please note that the Conti kit is also an option for the possible (probable?) flat, but you need to take out the valve stem, pour in the goo, replace the stem and then plug in the 12V compressor to get up and going. THEN you still have the issue of having your tire shop clean out the tire to get a good and proper fix done. I do not own stock in Shell Corp, but their inflato-can stuff is sensor safe so I'm going to use it when it is needed. BTW, it also requires the above mentioned cleaning.
Good luck with your request and I'm sure you will get many answers as well as many suggestions to do a search!
Old Jan 31, 2009 | 10:49 AM
BMT's Avatar
BMT
28K on my 07 and went with the Firestones. Very happy for the reasons stated previously. Cost, name brand, low noise and they are run flats.
Old Jan 31, 2009 | 07:33 PM
bassspring's Avatar
bassspring
I went with the Firestones and so far I have about 3K miles on them and like them enough to say I would buy them again. Bassspring
Old Jan 31, 2009 | 08:44 PM
60pilot's Avatar
60pilot
St. Jude Donor '08
Thanks! So hopefully I will have the pirelli Peeps chime in and tell me what they think.. but for the cost the firehawks are seeming like a good option..
Old Jan 31, 2009 | 08:57 PM
jrnorman's Avatar
jrnorman
Default I will go with Firestone Wide Ovals
When I need new tires that is what I am getting. I had them on my Z-28 and they were equal to the best handling tires I ever had on the car and were among the least costly and had the best ride and lowest tire noise. What else could you want?
On putting on new fronts and not backs. An old racer told us (on another forum) you always want your best tires on the rear even if it is a front wheel drive car. You never, ever want to loose traction on the rear first! EVER!
Putting new tires on the front with little or no tread on the rear is just asking for trouble especially in the rain.
Old Feb 1, 2009 | 09:27 PM
Hogvette's Avatar
Hogvette
The best advice I received on this question was that the performance difference between the PS2 ZPs and the Firehawks is certainly not as big as the price difference...
Old Feb 2, 2009 | 09:15 AM
jrnorman's Avatar
jrnorman
I think that is a good summary! If price is any part of your calculations the wide ovals would be hard to beat. Don't wait till the last minute though because there are reports they are often not immediately available - another good sign of the demand and desirability!
Old Feb 2, 2009 | 09:33 PM
Onyasix's Avatar
Onyasix
Default The Price, It was a No brainer for Me.
I got 18,000 miles out of my Goodyears. One of the front had excessive wear on the inside edge and in one place was showing threads. Probably could have gotten another 5,000 mile out of the rear.
I priced a set of Goodyear Eagle F1 EM at Carlisle last fall for $1,300 not installed, and a set of Firestone Wide Oval (run flats) for $1,000.
Well, it's good to have a friend that works for Firestone. I ended up getting a set of Firestone Wide Oval for $718.00 mounted and balanced. I couldn't pass up that deal. I know unbelievable. After his quote, I asked my friend several times to make sure they were the correct size and run flats.
I've been pleased with the tires. I can't say that I notice much difference between the Goodyear and the Firestone, but I did have extra money left over to help pay for the new black chrome wheels that I did purchase at Carlisle.
To Tire ?
