More C6 clicking
Old Feb 1, 2009 | 12:44 AM
CedFin's Avatar
CedFin
1st Gear
Default More C6 clicking
Hey,
Do anyone have any knowledge of or advice pertaining to a clicking noise in the front at low speeds when turning left or right?
I read about the axle bolt & lube situation for the rear clicking noise previously and I have noticed it also, but maybe I'm paranoid.
Old Feb 1, 2009 | 09:12 AM
i_york's Avatar
i_york
Sounds like CV joints. Classic symptoms.
Old Feb 1, 2009 | 09:30 AM
Dave O's Avatar
Dave O
You are not the only one. Check out the thread below. Pay particular attention to the posts from myself and Silverspeed. Bottom line, I solved my clicking issue by reducing the torque on the lug nuts to only 90lbs instead of 100.
http://forums.corvetteforum.com/c6-t...ick-issue.html
Old Feb 1, 2009 | 10:27 AM
Leprkon's Avatar
Leprkon
could be bad end links on the front sway bar. OEM pieces are not exactly hall of fame quality.
Old Jul 1, 2009 | 05:30 PM
railgun's Avatar
railgun
Replace lug nuts with aftermarket 1-piece.
To More C6 clicking
