RPM Wire tap in.
Old Feb 6, 2009 | 11:23 PM
BlueFish81's Avatar
BlueFish81
Default RPM Wire tap in.
Hello guys,
I am looking for the RPM wire so I can tap in under the hood. Please help me find the easiest place to tap in.
Thank you.
Karn
Old Feb 6, 2009 | 11:31 PM
BlueFish81's Avatar
BlueFish81
Opps I forgot to mention,
I have an 08 LS3 C6 6 Speed Manual
Old Feb 6, 2009 | 11:33 PM
BEZ06's Avatar
BEZ06
Originally Posted by BlueFish81
Hello guys,
Thank you.
Karn
I tapped into a Tach signal wire behind the instrument cluster for my shift light and input into my data-logger. If you're going to use it for an input to something inside the cockpit you might rather get the signal from inside the cockpit. If you want some pictures of getting a signal from there I can post some up.
If you're going to use it for an input to something mounted under the hood (maybe nitrous?), somebody else will have to give you some info on getting the signal from inside the engine bay.
So....it often helps to tell what you want something for to get the best advice.
Bob
Old Feb 7, 2009 | 03:23 AM
C6Antwon's Avatar
C6Antwon
On my 05 LS2 the wire is under the passenger side fuel rail cover on the gray connector next to the coil pack. Its the green wire on that connector.
Old Feb 7, 2009 | 05:52 AM
BlueFish81's Avatar
BlueFish81
Bob
I am going to install the FJO Progresive Controller and it is going to be under the hood. I found the TPS but could not find thr RPM.
Old Feb 7, 2009 | 09:48 AM
BEZ06's Avatar
BEZ06
Take a look at this thread - it might have some info for you:
http://forums.corvetteforum.com/c6-z...ch-signal.html
Bob
Old Feb 9, 2009 | 02:30 AM
BlueFish81's Avatar
BlueFish81
Tahnk you for all the info.
Karn
To RPM Wire tap in.
