I bought some HD sway bar end links and I am trying to figure out how to install.
They have a small bushing over the threaded bolt and one large washer with a hole small than the bushing so the washer won't fit over the bushing.
I don't know on which side the washer goes (hemi side or nut side) and does the bushing go in the hole in the sway bar end? and does the bushing go in the hole in the a-arm? If yes, then it appears that the nut will tighten against the bushing leaving some "play" on the sway bar ends.
