Vibration after clutch install
Old Feb 12, 2009 | 09:26 PM
maggiemike's Avatar
maggiemike
Default Vibration after clutch install
My friend's 2005 heads/cam corvette has a bad vibration after having a clutch installed. he has an aluminum flywheel and a carbon-ceramic clutch. There's a good amount of vibration when you rev it up in neutral and most noticeable on the highway around 4k rpm in 4th gear. any ideas what could be wrong?
Old Feb 12, 2009 | 09:36 PM
07MontRedcp's Avatar
07MontRedcp
Could be that the clutch assy is out of balance. When I had a new clutch installed the speed shop sent it to a shop that specialized in balancing engine parts.
BJK
Old Feb 12, 2009 | 09:47 PM
patton's Avatar
patton
St. Jude Donor '09
any smoother steping on the clutch pedal
Old Feb 12, 2009 | 09:57 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
You need to match balance the new clutch to the stocker... not to be misunderstood as zero-balancing. At final engine balance if the motor is off at all they'll install an off-balanced flywheel/clutch assembly to bring it w/ in spec. If you have one of these motors and install a zero balanced clutch you will induce a nasty vibration.
Happened to me... of course there are times new clutches just plain come out of balance even when every mfg. says they take great care to zero-balance them.
Old Feb 13, 2009 | 12:15 AM
Turbooo2u's Avatar
Turbooo2u
I've driven this car with the bad vibration. It's REALLY BAD. I could be wrong but it's hard to believe that the WHOLE car could vibrate because the flywheel/clutch/pressure plate isn't perfectly balanced.
Old Feb 13, 2009 | 12:50 AM
Luweegy's Avatar
Luweegy
I had a balencer go south last summer and I swore the torque tube and driveshaft came outta the car.This same car had the clutch installed wrong the day before.They bad clutch caused the balencer to go bad.Good luck.
Old Feb 13, 2009 | 01:02 AM
Mike's LS3's Avatar
Mike's LS3
BJK
When I did my clutches on my 72 Z28, I had the clutch assembly (pressure plate) and flywheel balanced together and never had any vibration.
Old Feb 13, 2009 | 11:15 PM
Turbooo2u's Avatar
Turbooo2u
Could a warped flywheel mated to a new clutch/pressure plate cause this vibration?
Old Feb 14, 2009 | 04:24 PM
glennhl's Avatar
glennhl
I had a Centerforce pressure plate throw some of the counter-weights on my 01 Z28. Did he put in a Centerforce?
Old Feb 14, 2009 | 05:54 PM
TehZ2's Avatar
TehZ2
Remove the new clutchand flywheel, check to see if it's balanced perfectly. If it is, then your OEM flywheel was used to balance the OEM rotating assembly and your new flywheel will have to be balanced in the EXACT way your OEM unit was. However, this is very unlikely as I don't think GM even has the capability to balance in this way (lots of aftermarket engine builders do this as a last ditch effort to balance a rotating assembly).
You better believe an out of balance clutch assembly will make the ENTIRE car vibrate like crazy! (and I would advise you don't drive this car ANYMORE until this is fixed. Said vibration is EXTREMELY rough on on moving parts in your engine)!
I recently sheered 2 of 3 of my torque tube bolts off the rubber grommet that connect the driveshaft to the clutch. Car vibrated like crazy in octaves above 1800 RPM. Thought it was my tranny. Replaced tranny, put it all back together, and started it up. Same problem. Absolute heart-breaker ( this is a 20 hour job on a TT car!!). Tore it all apart again (including torque tube this time) and found the sheered bolts. Oh, that was a fun day!
Point of the story above? Hang in there, it could always be worse!
To Vibration after clutch install
