Corsa Exhaust question
Old Feb 16, 2009 | 06:21 PM
Hard Rock's Avatar
Hard Rock
Default Corsa Exhaust question
How high do I need to get my C6 off the ground to install Corsa mufflers? I have a pair of 10 foot X 12" wide steel ramps and I'm thinking of making a pair of 10" high timber blocks. Does this seem to be enough? Thanks
Old Feb 16, 2009 | 07:12 PM
JJC5's Avatar
JJC5
The ramps should be all you need. Just back up on them.
Old Feb 16, 2009 | 07:43 PM
saplumr's Avatar
saplumr
I use 2 floor jacks and then support with jack stands.
Old Feb 16, 2009 | 08:19 PM
Hard Rock's Avatar
Hard Rock
Thanks but these are just flat ramps.
Old Feb 16, 2009 | 09:38 PM
miwung's Avatar
miwung
i jacked up the rear using a regular jack then threw jack stands under probably about 12 or more inches.
an hour max if you do it alone.
Old Feb 16, 2009 | 09:44 PM
Dave O's Avatar
Dave O
You should be fine. I used 8" race ramps. See my post below on my install.
http://forums.corvetteforum.com/c6-c...ipedreams.html
Old Feb 17, 2009 | 05:39 AM
Hard Rock's Avatar
Hard Rock
Thanks Dave I like the tip on using my floor jack to raise the car a few more inches for additional clearence and to expect to have to resize the front pipes. Thanks again and to all in the forum.
To Corsa Exhaust question
