Comparing 06'-09' Z51 models
Old Feb 16, 2009 | 06:39 PM
Turbooo2u's Avatar
Turbooo2u
Default Comparing 06'-09' Z51 models
I remember driving a friend's 06' Z51-equipped vert and thought the ride was pretty stiff and the car seem to have some bump steer. I didn't like it. I recently drove an 09' z51 coupe, and even in this cold weather, it drove like a dream..way better than my 07' Z06. Is there that much difference between these years other than engine size? I have my eye on a NEW 07' Z51 Vert.
Old Feb 16, 2009 | 08:04 PM
nwc6's Avatar
nwc6
The steering was changed in 08 to give more feedback, and 09 they added variable ratio to the steering.
Old Feb 16, 2009 | 09:40 PM
Walt White Coupe's Avatar
Walt White Coupe
All things being equal there should be no difference in the ride stiffness between an
06, 07 or 09 with a Z51.
Old Feb 16, 2009 | 10:47 PM
siffert's Avatar
siffert
There is NO difference in the Z51 suspension from '06-'09. Perhaps it
was the difference in the roads you drove on? It can feel like a dream on smooth roads and like a bucking bronco on washboard bad roads.
Old Feb 16, 2009 | 10:51 PM
Silver05GTO's Avatar
Silver05GTO
Could be the alignment too. There are some cars that wear out stock GY F1's in less then 10K miles, then there are some like mine that are going on 25K still with thread on them. Part of this is due to poor alignment from factory......the other part is a heavy foot!
Old Feb 17, 2009 | 01:11 AM
Walt White Coupe
And what does this have to do with ride stiffness?
Old Feb 17, 2009 | 11:18 AM
Silver05GTO
I've read from people that as the supercar tires age there is a drop in ride quality. Plus if the air pressure was jacked up.....more stiff ride.
Old Feb 17, 2009 | 02:36 PM
Walt White Coupe
No question that higher air pressures will make the ride firmer. Not so with tire wear or age. That will simply provide less traction as the tire tread hardens.
To Comparing 06'-09' Z51 models
