Tunnel insulation
Old Feb 19, 2009 | 06:36 PM
Larry R's Avatar
Larry R
Default Tunnel insulation
Not too long after purchasing my '08, I installed Exotic Vette's insulation kit. The improvements were notcieble. I also installed LAPD's 1/4 inch insulated tunnel plate. However, I was still getting heat into the console, albeit, less. So as an experiment, I removed the tunnel plate, took some of the leftover insulation from the kit, cut it to size and glued its to the inside of the tunnel plate and re-installed it. The noise level is lower and I believe the console is cooler. Just thought I's pass this on. Larry
Old Feb 19, 2009 | 08:09 PM
blackvetterzo6's Avatar
blackvetterzo6
My insulation kit is sitting in the garage waiting for warmer weather. Just wondering if you insulated under the console. I would think this would cool it down. I've read great things about the kit, cant wait to get started ripping the car apart!!!
Old Feb 19, 2009 | 08:22 PM
Modshack's Avatar
Modshack
I did that too with some Koolmat I had lying around...
Old Feb 19, 2009 | 08:28 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Very good idea, I'll have to try it, since I will have the exhaust out this weekend.
what type of insulation should be used???
Old Feb 19, 2009 | 11:41 PM
Larry R's Avatar
Larry R
Yes, I did insulate under the console. It is quite a lot of work to install the kit, but worth it.
Old Feb 23, 2009 | 02:56 PM
pmj341's Avatar
pmj341
I just ordered a 1/4" Tunnel Plate from Elite Engineering and it comes with the insulation Package, I might just add more in the tunnel over the tube.
Old Feb 23, 2009 | 05:58 PM
mustang196718's Avatar
mustang196718
+1. i've got the exhaust off right now also and would like to know. perfect opportunity for me to keep some of that stupid exhaust heat out of the cockpit.
To Tunnel insulation
