please advide on problem..tranny/converter?
I agree with C6 Batmobile that it's probably not your converter because it wouldn't go bad with the first transmission, magically fix itself for 300 miles and then go bad a second time.
On the off chance that it is the converter however, after you had it installed with the first transmission how many miles did you put on it before trying to load it up? Yank recommends that you don't do that or any WOT starts for the first 200 miles so that might also be a contributing factor.
Whether or not it was tuned specifically for the converter won't make a difference because with the exception of one airflow table, you don't need to make any changes to your tune when you install a converter.
My vote is that the fluid level probably isn't correct because I blew a line in my transmission cooler a few months back and without enough fluid in the transmission it acted very similar to yours - if you step on the gas the engine just freewheels and doesn't go anywhere.
Good luck,
Christopher
Hopefully the person that did the tranny rebuild did the swap so any installation issues are off the table. The only true way to know what broke first is to cut open the converter and examine the tranny together. Otherwise it becomes a game of finger pointing as to what broke first and which one polluted the other.
Did you put in a new converter with the most recent rebuild, or at least cut it open and clean it out?
