When we first bought our 2009 Automatic LS3 Coupe, leaving the traction control on and putting the gas pedal to the floor. The back end would bite down & it felt like it was going to pull the front tires off the ground ( little to no spinning of the rear tires ). Now that it has just over 2,000 miles on it & only running Chevron 93 octane in it. Leaving the traction control on, it is now spinning the rear tires all the way through first & a nice rip at second, is this normal ? Or is my traction control not working? Not even getting any traction control alarm flashing on the dash either. This happens in normal drive & sport modes. Many thanks in advance
Its possible that its not working. Does the car feel like its lurching a little. The TC works by pulling timing. If the car doesnt think its slipping it wont pull timing. Maybe your tires just arent gripping as well.
Maybe when you bought the car is was much warmer outside. Now it is much cooler. tire and road temp. has a lot to do with traction. Plus maybe you have a bit more wear on your tires.
No, the car does not feel like it is lurching at all. My tire pressure has went down a little though. It was at 31 PSI and is now at 28 PSI, I thought that this would help, but it has not. You may have a good thought on it being the tires ( run flats ). Thanks for the response.
The run flats tend to get harder and slicker with age it was this way with mine at least. I had pretty much the same problem the TC just didnt think the tires were slipping. I got new tires and it worked untill I just got rid of the TC compltely.
It was warmer when I bought the car in August temps in the 80's here in Louisana, now it is in the 50's / 60's.
Do you have the Z51 option with the "Supercar" tires? I bet you do. If so, sorry to say, your traction problems are directly related to colder ambient air temps. Those tires start to fall flat on their tread faces (read notoriously poor traction) when stomping on the gas at around 55* and really gets bad below 45*. As for your rear tires pressures, you will get better traction at 27-28 psi, providing the air temps are in your tires traction range.
Do you have the Z51 option with the "Supercar" tires? I bet you do. If so, sorry to say, your traction problems are directly related to colder ambient air temps. Those tires start to fall flat on their tread faces (read notoriously poor traction) at around 55* and really gets bad below 45*. As for your rear tires pressures, you will get better traction at 27-28 psi, providing the air temps are in your tires traction range.
We didn't even realize or think about this being an option, but it sure does make sense. Can't wait for Summer to be back!! Thanks
When those Supercar tires go (and they will), you might want to consider getting something other than ultra high perf runflat tires next time. I run Goodyear Eagle F1 AS/C (all season) runflats on my car.
I sacrifice a bit of grip in high temps but they really shine below 55*. In fact, I can go from a red light at WOT with NO traction/spinning problems at 20*!! Try that with those SuperCars! On second thought, dont-you'll be off the road! Seriously, you have to be very careful with those tires in mild/colder weather.
If your tires are spinning and spinning, you definitely have a TC problem. IT IS NOT A TIRE ISSUE NOR A TEMPERATURE ISSUE. My TC keeps my wheels from spinning in the snow / ice...
I think you misread the OP. He wasnt describing 100% spinning all the time, just when "putting the gas pedal to the floor". I think you should recheck the tire model you got if you can punch it from a standing start at WOT in snow or ice conditions and getting no spinning on Supercars even with TC on. Dont think you got them on your car.
I don't spin even on ice & snow as I said. Sure, the tires will break grip very briefly, but TC kicks in and there is no spin unlike OPs post that describes, "spinning the rear tires all the way through first".
And you are right, I have winter tires, but has nothing to do with what I believe is being decribed.
Ah ha, it finally comes out you got winter tires! I wonder why?
You can get spinning of the SuperCar rear tires all the way through first gear (and even 2cd gear) even with TC on if you keep the throttle to the floor in snow, ice, cold/mild ambient temps or even with 600 hp. While the TCS system attempts to limit spin (with the driver aiding it by deaccelerating) , it does not neccessarily eliminate it.
I think the core issue here is indeed I and the OP differ on what "you think is being described here".
Try driving it with the TC off, then on. Is there a difference?I drive mine with it off most of the time. Get use to driving the car with it off. Then if one day you do jump on it you will know how it will react.
I will try this out tonight, the temp's will be in the 40's. This will be the first time, that I would be turning it off. Can't wait to see what it does. Thanks for the response.
Those SuperCar tires give Super poor traction in the 40's whether its TC on or off when flooring it. Be careful, make sure no other cars are around. This testing is better done in above 55* temps.
Look's like siffert was right. Today the temperature outside was 73 & the Vette is back to it's old self again. Very little to no spinning & trying to lift the front wheels off the ground I ran a Dodge Challenger today from a red light and let's just say, he will be thinking twice before running a Vette again
Tomorrow the temperature is exspected to be in the high 70's and I can't wait to find my next victim
There is no greater satisfaction than getting good grip at the light and blowing off victims. Your next task is to practice with TC off (in warm weather with the tires warmed up). You will get faster times off the light (albeit at a possible slight loss of traction-ie: more spin) without the computer controlling your traction. Dont forget to always make your street "runs" in "S" mode-its the fastest mode and will shift for you near redline. Rear tire pressure should be set at 27-28 lbs cold as well. Good luck!
