Roller rockers for LS3
Old Feb 22, 2009 | 10:43 PM
lockman's Avatar
lockman
Default Roller rockers for LS3
ok what is the stock size for roller rockers on the ls3? I think it's 1.7 but haven't found out for sure.
Are they worth getting? and is there any modification needed to the heads to make them work?
I'm going to be installing a cam here very soon also so it will be opened up and everything anyway so labor isn't a concern just wondering if they are worth the price tag or should I just use the stock ones again.
Thanks for any info.
Old Feb 22, 2009 | 11:34 PM
adam205348's Avatar
adam205348
Yes I do believe they are 1.7 ratio
Old Feb 23, 2009 | 04:16 AM
kaislick's Avatar
kaislick
yella terra makes a bolt in replacement for stockers, love em. Not real expensive either.
Old Feb 23, 2009 | 09:30 AM
vertC6's Avatar
vertC6
Are the yella terras adjustable or do you just bolt them up with the correct pushrods?
adam205348's Avatar
adam205348
Yeah here is a link if it will work to their website for 3 different ratios. 1.7 (stock), 1.8, and 1.85
Old Feb 23, 2009 | 11:05 AM
mikesul's Avatar
mikesul
Crane just came out with some for the LS3 also.
Old Feb 23, 2009 | 12:08 PM
CMY SIX's Avatar
CMY SIX
rollers ARE worth it!!! love my crane's
Old Feb 23, 2009 | 05:01 PM
lockman's Avatar
lockman
thanks for the info I'll see if I can find them the only ones I found so far are 1.8 and I'm not sure if they will work with the cam I'm putting it. the cam is a whiplash from england green.
To Roller rockers for LS3
