Short belt?
Old Feb 24, 2009 | 08:41 PM
dsp300c's Avatar
dsp300c
Default Short belt?
I bought a Meziere electric water pump. I know the pros and cons of it. But that is my concern.
I have heard you can use a shorter belt b/c you don't need the belt to run the water pump.
Does anyone know what size belt I could run to bypass the electric water pump?
Thanks,
Andrew
Old Feb 24, 2009 | 09:59 PM
Fasrdnu's Avatar
Fasrdnu
Thanks,
Andrew
Call Meziere they should know 760 746 3273
I asked them several question myself including emails they didnt even know how to wire their own wiring harness for the pump that they made????
This is another reason I do alot of research anymore before I do anything.
There are so many tuners that think they can work on these cars that just cant. Its sad but true
Good luck
Old Feb 24, 2009 | 10:16 PM
dsp300c's Avatar
dsp300c
Good luck
i bought that ZIP harness which is to make the pump plug and play and if the pump went out then it would shut fuel off to the car so it wouldn't overheat...i asked my local shop and i'll be picking up a belt next week...they said run stock belt on the street and short belt at the track...
Old Feb 25, 2009 | 11:49 AM
FloydSummerOf68's Avatar
FloydSummerOf68
There is no reason to run the stock belt EVER with the electric water pump...
Old Feb 25, 2009 | 08:34 PM
Fasrdnu's Avatar
Fasrdnu
I called and emailed Meziere Jay Carson was who I spoke with He him self Said you with see No gain that pully free wheels. 0 drag.
Do you have the part# for the belt??? I try it and post the Numbers before and after the pump and before and after the short belt.
Part # and the name of your shop. You can PM me if you like.
Thanks in advance
Mike
Old Feb 25, 2009 | 08:56 PM
dsp300c's Avatar
dsp300c
Thanks in advance
Mike
i will see if they will do a stock belt vs. short belt dyno. i am going on march 5th. i'll let you know.
Old Feb 25, 2009 | 09:38 PM
Fasrdnu's Avatar
Fasrdnu
PM me
Mike
Old Feb 27, 2009 | 08:15 PM
dsp300c's Avatar
dsp300c
i received an email from a forum member but can't remember who it was...if you read this please send me an email to andrew.oswald@verizonwireless.com i have a question i need to ask
To Short belt?
