Strange noise. Possible drivetrain problem?
I have recently noticed a whine coming from the car while driving. At first I wasn't even sure if it was something new, but I started noticing it when coming to a stop. It has a whirring attribute to it, indicating it has a rotating source.
I only hear it when the drivetrain is under load. Engine and exhaust noise drown it out when accelerating, but I hear it a little when cruising, and hear it most when decelerating.
The pitch changes with road speed, independent of what gear is selected or engine speed. But in a lower gear (more load) it is louder. It seems to be most prevalent at about 45mph.
If I push the clutch pedal, it goes away immediately and completely.
When cruising it isn't constant. It comes and goes as the drivetrain alternates between load and coasting.
What do you guys think?
any possibility of one of those listening devices that you can snake into the engine compartment while running?
No. Can I inspect it without dropping the torque tube?
If the sound meets all those conditions:
• Wheel speed
• With or without power
• With or without the clutch applied
That leaves things that always rotate at the same speed as the wheels:
• Wheel bearings
• Differential bearings
• Ring and pinion
• Transmission tail shaft bearing.
So I guess it could be any of those but I personally have never seen it be a transmission tail shaft bearing.
As suggested if you can get it safely off the ground and listen underneath you might be able to pin point a wheel bearing but differentiating between the transmission tail shaft bearing and the differential will be a lot harder because they are almost one unit.
Bummer! Let us know what you find out; we might all learn something!
