How to remove headlight assembly?
Old Mar 5, 2009 | 07:51 AM
Dylan 93Z's Avatar
Dylan 93Z
Default How to remove headlight assembly?
Are there any how-to's out there or anyone with knowledge of how to remove and replcae a headlight assembly on the C6? Thanks!
Old Mar 5, 2009 | 09:43 AM
tech8381's Avatar
tech8381
2nd Gear
There may be an easier way but how I do it to prevent scratching anything is remove the front fender liners. Remove front bumper. Loosen front fenders enough so I can pull them up about 3 inches. Remove the 3 10mm nuts that hold the lamp in. Pull up on the headlamp to clear the studs then pull straight out. It's a real PITA.
Old Mar 5, 2009 | 12:39 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
+1 About the only way I've seen to do it and not run a high risk of scratching. If you have a helper you may get by with removing about half the screws in the front cover and pulling away enough. Better have a trusted friend...
Old Mar 5, 2009 | 06:42 PM
CroOrange's Avatar
CroOrange
Here's my two pence on this:
http://forums.corvetteforum.com/c6-t...een-up-to.html
a++ Cedric
To How to remove headlight assembly?
