installing headers question
Old Mar 5, 2009 | 08:06 PM
comes alive's Avatar
comes alive
Default installing headers question
Is it ok to use the stock gaskets for my headers if on both gaskets on 1 end came apart at the indintation? Both gaskets look really good no deformities. Im thinking if I reuse them they will be fine, but I just wanted to make sure before I bolt the headers on tommorrow morning. thanks
Old Mar 5, 2009 | 08:52 PM
Fast06Z06's Avatar
Fast06Z06
I resused mine. No problems since. Seemed way better than the header companies header gaskets. Plus I wasnt about to spray gasket sealant on both sides of the new metal gaskets as they recommended and then install.
Old Mar 5, 2009 | 09:28 PM
silvervette05's Avatar
silvervette05
I reused my stock gaskets when i installed my z06 headers..and then had to turn right back around and do it over again because the driver side leaked..They looked to be in perfect condition..I think once that metal splits open you need to get new ones..Best of luck bud..
Old Mar 5, 2009 | 09:38 PM
Bludog's Avatar
Bludog
I think I spent about 20 bucks for new GM gaskets even though my old ones looked good. For 20 bucks it wasn't worth it to take the chance for a gasket failure and have to redue it again.
Old Mar 5, 2009 | 10:00 PM
comes alive
Default gaskets
thanks all
To installing headers question
