MGW C6 shifter install help!
Old Sep 7, 2009 | 05:27 PM
GotVett?'s Avatar
GotVett?
Originally Posted by '06 Quicksilver Z06
As mentioned before, it can be obtained with either or both the threaded and the non threaded shafts. The threaded will accept a wide variety of threaded shift *****.
If you wish to change from one to the other, there is no need to remove the console again, you can simply remove the **** and shift boot to change shafts.
Very good then. Thanks again D.
Old Sep 7, 2009 | 09:31 PM
rectifyer2000's Avatar
rectifyer2000
Originally Posted by One Bad Vette
He really did answer the question though. It is as simple as removing the console, the four bolts that hold the stock one, apply rtv or gasket to the new one, and reinstall. Kinda easy...
Everything is easier after you've done it once. If somebody on here is asking for specific details on a project, we should give them the information he/she needs to help them. If I was to tell my wife that "Changing a tire is easy, just losten the lug nuts, jack it up and put on the spare", that would NOT be helpful to her. Some folks need step by step instuctions to feel comfortable. We shouldn't clown them because we think it's easy. Know what I mean?
