Nitrous ???s
Old Mar 12, 2009 | 12:46 AM
  #41
SpinMonster's Avatar
SpinMonster
Originally Posted by tractionlessvette
finished hooking up the kit properly but the bottle pressure was was low so Tom i will try to raise the pressure and see if the kit is working..
To have finished the wet shot install, all you had to do was move the nozzle forward to the MAF plastic past the element.
Dry shots dont vary a/f ratio by bottle pressure because the MAF measure the nitrous and adds the right amount of fuel. This means the shot should work as a 75 shot at 600psi and like 100 shot at 900psi.
Old Mar 12, 2009 | 07:11 PM
  #42
tractionlessvette's Avatar
tractionlessvette
Nice my hope now is done the drain.. lol
Going wet I would have to get the Y split to go to the sprayer plus bigger injectors and pump.. Until then I was hoping to see how dry is working.. Had 600 psi and it bogged/fuel cut again..
Old Mar 13, 2009 | 12:32 AM
  #43
HANNY's Avatar
HANNY
spin, is the nos injection suppose to be after the MAF? not before it? and do you think maybe he is only getting fuel spray? i have had that happen and it causes a very rich condition. "One" of the reasons we use to run the vent for them at the track. just a thot, paul
Old Mar 14, 2009 | 02:11 AM
  #44
tractionlessvette
I dont have fuel spraying because its a dry kit.. but i do get what i believe is a rich bog..
