Retractable Spoiler Design Concept
I suspect that the initial goal in your design was just to do something different; nothing wrong with that. Just be honest with us up front. I'm sure there are plenty of people who will buy a motorized spoiler just to watch it go up and down.
Peace!
Yes reducing lap times at a road course is a top priority for the design. Will the benefits be realized on the the street as well as the track? Too early to tell.
Is the goal of the product to do something different just for the sake of doing something different? Of course not. I have stated that repeatedly here and in the other posts as well.
Not to mention the basic idea of the design concept is not new. It can be found on Porsches, and Mercedes. Application of the concept to the Corvette world is what is new.
Anyway, I wish you the best of luck. It appears you don't need to actually prove your theory anyhow - you seem to have some willing buyers no matter how expensive or ineffective, just as long as it motors up and down.
A few points, cut down a bit so as not to bore everyone:
Most of the aerodynamic behaviour of a car is determined by its overall shape.
There is a difference between a 'wing' and a 'spoiler'. A wing is exactly what it says, like an aircraft wing, designed to purely produce downforce when applied to a car (or upforce on a plane
)A spoiler is VERY different - it is actually used to just detach the airflow from the car body. Those thin 'lips' you see on hatchbacks, or trunk lids, are actually very effective at detaching the airflow and reducing lift.
This design is aiming to be a wing, and generate downforce. HOWEVER, it will only ever genereate downforce on the rear, and the nature of the design, especially in the raised position, will REDUCE downforce at the front of the vehicle if no other changes are made. If you found that the front of the vehicle is already a little light at speed (which it is on most average passenger cars), this will make the problem far far worse. (Imagine a huge force pushing backwards on the wing - it will act like a lever and lift the front).
To really get any benefit in terms of vehicle performance on a track, you'd have to finely balance front and rear aero changes to get a combination that gives an improvement to both as equally as possible. Even putting a Z06 rear spoiler on your car without the Z06 front end is going to have some effect on the balance that GM designed the cars with.
Don't be fooled by small sizes when talking about wings - they can generate pretty huge forces with the correct design.
Nobody has mentioned this yet - but any wing, especially ones that are raised up from the trunk lid, will substantially increase DRAG. Race car teams are continually trying to balance downforce and drag - at some tracks they will opt to reduce downforce, and hence get lower drag, in order to get a higher top speed (with slightly lower corner speeds). As already mentioned, it is a BALANCE. Without any benefit in downforce, any wing will just be costing you in terms of drag - top speed and acceleration at higher speeds will be hurt (As well as MPG, but not many of us care too much about that).
So, in short, there is a lot more to aerodynamics than a lot of people realise
The wing will reduce top speed from 186mph to 180mph.
At 100mph, the air force pushing backwards on this wing will be nearly 50 Newtons (11lb) (more if I include the struts). At 180mph, it is 150 Newtons (36lb)
While looking for the data for the standard C6, I also discovered the the Z06, with its wing and front end changes, has an increased coefficient of drag of 0.34 over the standard coupe, which is 0.28. That's a big expense for extra downforce.
One comment to Roastbeef . . . I'd guess that most of the additional drag on a Z06 comes from the wider tires and fenders. I could be wrong though.
