Just picked up my 07 from having Varram/AR headers/xpipe with hi flow cats/BB Fusions/NPP in a box installed. 30 miles from the shop the check engine light came on and the oil temp was up to 234 on the trip home with OAT at 78 to 80 degrees. No tune has been done. Stopped by Advance and the scanner there would not read the code, it gave off a system error
Can anyone offer information on the check engine light. What is the normal oil temp on a LS2 and is 234 at 80MPH too high on a 78 degree day?
Called Chuck COW. Will get a MO tune. I'm real surprised at no response here though. I thought someone may at least respond with the normal oil temp range for an 07 LS2 A6.
