Coilovers.....What exactly do they do??
1.PRECISION
2. ADJUSTABILITY
When you are driving a stock car at 8 to 9/10th of it's capabilities, then coilovers make a big difference, as would going to dot -r from street tires, and so on and so on. I think as far as GM goes it is a cost savings and heritage item. Puttin a set of $80 shocks per corner v 250 to 500 shock. I even put upgraded coilovers on my Lotus and it came stock with CO, This made the car transition better, dive less during braking, lift less during acceleration, loose over/under steer problems, corner balance it to the lbs. plus most sytems let you soften them up for comfort so it is all good. Just $$$$$.
1.PRECISION
2. ADJUSTABILITY
I'm a bit confused about the term "comparable spring rates." How do leaf spring rates compare to coil-over spring rates? Would coil over spring rates be identical to leaf spring rates?
Coil-overs on the rear of a C5/C6 are an compromise as the suspension moves up the shock angle gets very funky. In fact, C6Rs have modified shock mounts for this very reason.
Never said coil-overs were bad... but most guys on here do them for the wrong reasons. You can achieve the same results w/ leafs. The perceived handling benefits are from higher rate springs and better shocks... not swaping from leafs to coils.
For all out racing on a road course, coil-overs are the best, and will yield the highest performance, though the margin can be narrowed by smartly modifying the leaf setup.
For every day driving, the difference is noticeable in feel but not in performance.
My dad has a C5 Z06 with coils and I have a lowered C6 Z51 w/ Bilsteins and PFADT bushings. I could not tell which one handled better; on flat surfaces and smooth roads the cars felt the same. The only area the C5 Z06 felt a little bit better was on particularly rough roads, but the difference was not that significant, and I think Michelin PS2s on the Z06 versus runflats on the C6 play a significant role in that as well.
You may be happy with the coil-overs; my dad dialed in the ride height to his exact preference. Also, for people who love modifying and getting parts just for the sake of beefing up the car... why not get coil-overs?
Most people will never push their stock suspension beyond its limits because of ability (by mistake is a different story
) and because the stock tires will most likely give out before the suspension. Dont forget your tires have a lot to do with how your car is going to handle so upgrading your suspension alone is not really going to improve your handling to the degree that you think it will.I have Hardbar Dual Rate Coilovers with Triple Penske Shocks. The ability to change my setting when I want to is a great improvement over the stock suspension and also a great improvement over my first set of coilovers.
My stock suspension I tried to help by adding a T1 bar. It did help, but still not what I wanted. I added mid-level coilovers which were fantastic on smooth surfaces, but they really didnt work that well over various transitions. This probably would not make a difference to a street driver, but at the track I aggressively cut many corners which will throw the car out of balance and I needed a suspension that could handle that better.
Finally I ended with my current setup. These are more suited for the driving I do, but I found out over a few track events that the T1 bar had to go. I am working on testing now to see what size bar I want, but I can tell you now it will be alot smaller than the T1 bar. The reason is I have a good setup and want to reduce, as much as possible, any connection side to side.
As with everything, think about what you want from the car and then plan accordingly. A change in swaybars, shocks and tires will make a big improvement on the street and save you a lot of money, but coilovers are
I try to learn FIRST, then modify if I need to... It's worked out so far.
you dont need them.
