Silverado 2500HD - LS2 motor?
Old Mar 16, 2009 | 07:59 PM
c6turbo88's Avatar
c6turbo88
Default Silverado 2500HD - LS2 motor?
Does the 2008 Chevy Silverado 2500 HD with the 6.0 liter motor have a similar motor as the LS2 motors? They're rated at 360hp 380 tq
Old Mar 16, 2009 | 08:18 PM
timd38's Avatar
timd38
Pretty darn close!
Old Mar 16, 2009 | 09:44 PM
dbradley's Avatar
dbradley
The truck L76 has better heads, WORSE intake and variable valve timing and is tuned to run on 87.
Old Mar 16, 2009 | 09:45 PM
CPhelps's Avatar
CPhelps
That is the LY6 which is not an LS2. It has the same bore x stroke as the LS2, but an iron block, and 9.6:1 compression ratio as opposed to the aluminum block and 10.9:1 compression ratio of the LS2. Fuel cutoff is also at 6000 rpm instead of the LS2's 6600, and recommended fuel is regular while the LS2 recommends premium. I also assume it has the truck intake/accessories. Unlike the LS2, it also features VVT. Most likely has a different sized camshaft as well, but that is also just a guess from me.
It is more of a Gen IV successor to the LQ4, and I suppose could also be considered an iron block version of the L76 engine found in some trucks and also the new Pontiac G8 GT.
To Silverado 2500HD - LS2 motor?
