VSS output from ECU for shift / launch light?
Old Mar 19, 2009 | 01:45 PM
C6-13thPilotCar's Avatar
C6-13thPilotCar
Default VSS output from ECU for shift / launch light?
Does anyone know or have the wiring information for the HUD on an 05 C6. I need to connect into the Vehicle Speed Sensor output signal from the ECU to install a new Raptor Launch / Shift light.
Question answered, found answer from e-mail to Raptor support. Instrument panel cluster connector, Pin #6, ECU connector C1- Pin#55.
Wire color is dark green with white stripe.
Last edited by C6-13thPilotCar; Mar 19, 2009 at 04:10 PM. Reason: Found answer from vendors site
