?ARP Balancer Bolt Torque
Old Mar 20, 2009 | 10:23 AM
N2O4YOU's Avatar
N2O4YOU
Default ?ARP Balancer Bolt Torque
Need torque specs for ARP Balancer Bolt.
Old Mar 20, 2009 | 10:44 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Does this help?
http://forums.corvetteforum.com/1567800214-post1.html
I'm still looking.
Elmer
Old Mar 20, 2009 | 06:36 PM
N2O4YOU's Avatar
N2O4YOU
thanks for info. Search function doesn't seem to be narrowing down post for me.
Old Mar 20, 2009 | 08:42 PM
MrDrezzUp's Avatar
MrDrezzUp
I just finished installing one...27 MM 12-point socket.
Old Mar 20, 2009 | 09:08 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
I just installed one and I used 240ftlb and lube on the threads!!
Old Mar 21, 2009 | 01:43 AM
Redrocket1045's Avatar
Redrocket1045
Default ARP damper bolt torque
I read somewher on the forum that ARP recommends 190 ft. pounds of torque.
Old Mar 21, 2009 | 01:53 AM
HuskerBullet's Avatar
HuskerBullet
ARP uses a much stronger material in manufacturing their bolts (don't stretch as much) and, therefore, don't need as much torque as the OEM bolts; they are weaker and stretch more.
However, if you have replaced the OEM pulley with an underdrive pulley, and using a crankshaft pin kit to install two pins, and using the ARP bolt (I have all three, but I haven't installed them yet), then I have been told you only need to torque it just like the old chevy pulleys and crankshaft that were keyed; 65 lb-ft. Then, the 240 lb-ft is ludicrous. But, no pins, then you must go with the massive torque.
Old Mar 21, 2009 | 07:29 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Did you try calling ARP?
Old Mar 21, 2009 | 02:40 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
That won't up his post count . . . . . or yours . . . . . or mine
Old Mar 21, 2009 | 05:06 PM
kelp's Avatar
kelp
I put 300 l on mine - and pinned the balancer. I know, it's nuts, the car is nuts anyway.
Old Mar 22, 2009 | 05:59 PM
N2O4YOU's Avatar
N2O4YOU
Thanks everyone. Think I will go with the 240.
Jim
Old Aug 27, 2025 | 01:39 PM
cjtwigt's Avatar
cjtwigt
1st Gear
Hi pmj341,
I'm installing a new harmonic balancer next month and I intend use the ARP bolt with ARP lube.
Has your bolt ever come loose or has it held up nicely. Pleas let us know.
Regards,
Chris
Old Aug 27, 2025 | 02:11 PM
gdmoore01's Avatar
gdmoore01
Doubt you will get an answer as his last forum activity was 02/2014 11 years ago. You should start your own thread and I am certain you will get an experienced user reply.
Also, welcome to the Corvette Forum & be sure to post a PIC of your Vette.
GD
Old Aug 27, 2025 | 02:45 PM
oussie's Avatar
oussie
Mine came loose with arp grease.
After that blue locktite, and again came loose.
Did set it on 240ftp /350Nm
Now pinned it, blue locktite and it sits for 3 months pff
Old Sep 5, 2025 | 09:43 AM
Orion2011's Avatar
Orion2011
I've done two C6 balancers. Used ARP @ 240 ft-lbs lube threads with ARP lube.
Old Sep 5, 2025 | 10:28 PM
Malfeitor's Avatar
Malfeitor
Pretty sure the grease is for the bolt flange and washer interface to get accurate torque spec and not gall the flange/washer. Don't think you are supposed to grease the threads. I've done 2 ATIs with ARPs LS2 and LS7 this way and used ONE drop of red loctite. Neither have come loose.
To ?ARP Balancer Bolt Torque
