G5X3 cam - trying this again
I really like th esound of this cam, but I just want to make sure i dont sacrifice too much driveabilty, and I also want good bottom end power
any advice would be great
Denis
Denis
In short, get thin gaskets to increase compression to 11.4, and get the newly designed G6x3, it's a newer design that gives more torque.
The cam is easily tuned an the car can run and drive like stock. I have daily driven mine for almost 2 years now and it's great.
but it SOUNDS super tough at idle, however that might be because he had his cut-outs open . . . . . . . .
The G5X3 was a fantastic cam, but the G6X3 is a variation of the theme aimed at the LS2/LS3 platform and performs extremely well.
I do love when guys pull up next to me hitting their turbo blow off valves (sounds like blowing their nose to me)...my car's so quiet they think it's nothing...until I open the cutouts...I love the surprised look.
And for the record I don't bother racing on the street. Spinning my tires is all that accomplishes.
Here's a clip:
I thought long and hard about gears but I don't want to do that in my DD that sees a lot of highway miles. And it's not necessarily an issue of regretting the cam choice so much as it's moving along in preference... It does sound phenomenal, though.
I thought long and hard about gears but I don't want to do that in my DD that sees a lot of highway miles. And it's not necessarily an issue of regretting the cam choice so much as it's moving along in preference... It does sound phenomenal, though.This again is another vote for bumping the compression up on the heads and/or doing a FAST manifold in addition to the cam. Both increasing the SCR on the head and/or the fast will increase the torque curve down low and result in more seat-of-pants fun.
I also had a C5 a few years ago with the G5X1 and that was a fantastic around town cam. You give up the top-end to a bigger cam like the G5X3, but it was a fantastic cam in its own right.
I had it too. Great cam, but i wanted more low end. Went with the GT-11. (Not quite as strong up top, but low/mid is much more fun. Does'nt lope at 700rpm, but will at 550rpm) Lot's of choices of cams out there, so choose what fits for your long term enjoyment.
My dad (also my mechanic) called LG today and they told him they can send me a "mailorder" tune... they're send me software & Laptop-to-OBDII cable ($500), then email me a program ($350). Anyone do this?
or... I found a local tuner that can do it... what should I do?
Denis
The scanning is invaluable if you track your car. You can tell so much about your car, what it needs, and a lot about your driving skills too. If you look at my personal best threads recently you can see some scan examples and people offering suggestions. Many more such examples on the HP Tuners forum.
Besides being fun, learning to time can
end up saving you money as it keeps you from having to get a retune with each mod. If you get HP Tuners you should get a Wideband too, it's needed to tune open loop full throttle AFR. You can also use a dyno for the Wideband, but it's really nice to have it on the car if you track the car.
I only have cam, headers, intake, exhaust, and tune. I imagine if I downgrade the cam, put on the remaining bolt-ons, and retune it, I can get 420/420 with more torque down low. That torque is what makes it fun, and keeping a stock-like curve is important.
Aside from that the sound is amazing and it does make the peak numbers...
I track every gallon of gas in my Vette since new - the gears lost me exactly 1.0 mpg. I daily drive mine mostly city, about 3 highway miles per day. Highway mileage is still high 20's with the gears, you won't notice much of a difference based on my studied experience.
Here is a graph to show the difference on a dyno as to why gears make such a difference, particularly down low.
The first graph is my car (pre-FAST) and Black02SS...same G5x3 cam, he has a FAST, stock gaskets, I have thin gaskets, thus more compression and 3.90 gears. The X-axis in this graph is the RPM range. No it's not the same car!
Now look what happens when I change the X-axis to speed....and look how much more horsepower I have at any given speed than Black02ss has....this graph proves, on the dyno, why geared cars feel so much faster than non-geared cars. You have 20-30 more HP at any given road speed!
I have driven a 4.10 C5 with a cam in it before and it was quite a fun ride on the street. Obviously 3.90's would be more sensible, but I agree that gears are a worthwhile mod.
I still don't have LT headers, and I may wait a little ($$) to get these. What power difference between with & without headers? (I do have BB bullets & Vararam now)
thanks
Denis
With the new LG Super Pro's hitting the market soon you may want to keep an eye out for a used set of LG Pro's that you could get for cheaper than retail
