Underdrive Pulley install...$750?!?!
Old Mar 25, 2009 | 05:21 PM
StoplightWarrior's Avatar
StoplightWarrior
Default Underdrive Pulley install...$750?!?!
A local shop quoted me $750 to install an underdrive pulley on my 08 c6. They basically said that they knew I wouldnt pay that much to install, but that it is listed as a 7.5 hour job, and it's not worth doing unless I'm also installing a Cam at the same time...
Would it really take a shop 7.5 hours to install??? I could do pulleys on Mustangs in 30min.
Old Mar 25, 2009 | 05:29 PM
lockman's Avatar
lockman
yes it would you have to take the steering arm off to get to the pulley or you have to take one side off and pull it up to the other side to get it off. and Thank GOd this isn't a JUNKSTANG lol
Old Mar 25, 2009 | 05:51 PM
knkali's Avatar
knkali
big job
Old Mar 25, 2009 | 05:54 PM
StoplightWarrior
this confounds me.
Old Mar 25, 2009 | 05:59 PM
c6 batmobile's Avatar
c6 batmobile
You have to remove everything in front of the motor basically. Its pretty extensive and labor intensive.
Old Mar 25, 2009 | 07:02 PM
LEAVINU's Avatar
LEAVINU
Old Mar 25, 2009 | 07:03 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
It is a job, and you would save money by doing the cam at the same time!!!!!!!!!
Old Mar 25, 2009 | 07:54 PM
BIGB23's Avatar
BIGB23
WOW. never knew it was tha big of a job
Old Mar 25, 2009 | 08:17 PM
da vette guy's Avatar
da vette guy
shopkey has it listed at 7.2 hours, i've made less time for r&r engines before,damn i need to leave my dealership(ford,lincoln,mercury) and start working on Chevy's.....
Old Mar 25, 2009 | 09:49 PM
c6 batmobile
Well corvette's at least.
Old Mar 25, 2009 | 10:33 PM
GMautotech's Avatar
GMautotech
BTW, I believe warranty time is 4.5 hours.
Old Mar 25, 2009 | 11:26 PM
HuskerBullet's Avatar
HuskerBullet
Wow, that cost is $100/Hr? Well, I plan on doing my own install in a few weeks, but it's true, the steering rack and pinion assembly is directly in the way of the pulley, like about an inch. So, it must be removed, but I wouldn't think it would take all day to do it; I guess I'll find out in a few weeks.....
Old Mar 25, 2009 | 11:52 PM
da vette guy
can you beat the W time? after working on Fords for 20 plus years, working on the space shuttle would be easy. have you seen under the hood of the 6.4 diesel? i think Ford hates their technicians and by the way our labor rate is 85 an hour
Old Mar 26, 2009 | 12:17 AM
TinSecondRice's Avatar
TinSecondRice
St. Jude Donor '08-'11
Off topic, but are the 6.4's really as bad as people are making them out to be?
On topic- This "mod" is not even worth it if you aren't changing out the cam. Not only b/c of the cost, but also the minimal gains. It is definitely not worth doing for the few hp you may gain. Wait til cam time, then have it done.
Old Mar 26, 2009 | 08:32 AM
da vette guy
not near the problems the 6.0 had when it came out,most engine repairs call for the body to be removed on the 6.4 diesel.....
Old Mar 26, 2009 | 02:10 PM
StoplightWarrior
Well, on mustangs you gain 7-10hp and the part is $100 and takes 30min to install, so they're WELL worth it.
Guess that's not the case on the c6
Old Mar 26, 2009 | 02:59 PM
dennis50nj's Avatar
dennis50nj
Roy at Cartek did mine in a couple hours, removed it drilled the crank pined and put on
To Underdrive Pulley install...$750?!?!
Old Mar 26, 2009 | 03:35 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Only a 3 to 3 1/2 hr job....
Old Mar 26, 2009 | 04:55 PM
StoplightWarrior
now I'm getting some preferable responses...keep em coming, hopefully!!
Old Mar 26, 2009 | 10:01 PM
GMautotech's Avatar
GMautotech
I have only done one balancer and it took me 4-4.5 hours. If I did a couple more then I could get it down to the 3-3.5 that Chris@ECS mentioned.
off topic - our duramax isn't fun to work on either. I have a turbo to replace soon and the body will be coming off.
