skip shift eliminator
Old Mar 28, 2009 | 09:24 PM
yello9's Avatar
yello9
Default skip shift eliminator
Hello to all of you Vette enthusiasts. I'm new to this forum having just taken delivery of my 2009 coupe three days ago. I was wondering if any of you had installed a skip shift eliminator and what your views were on these devices. I do understand the reason for the skip shift and consider it an annoyance more than a problem.
Old Mar 28, 2009 | 10:14 PM
REVAK's Avatar
REVAK
Default skip shift
The skip shift eliminators work well, or you can use a 2.2k resistor across the connector at the solenoid on the trans. Also the skip shift can be programmed out with a predator or hp tuners. Most of us manual guys don't like the skip shift function and promptly disable it.
Old Mar 28, 2009 | 10:37 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I disabled the CAGS with HP Tuners and no needs for the resistor.
Old Mar 28, 2009 | 11:44 PM
tmak26b's Avatar
tmak26b
Don't ask me how, my transmission shift into 2nd smoother (at low or high RPM) once I disabled it.
I just used the "blow up" the COGS fuse technique, it works great as far as I can tell.
Old Mar 29, 2009 | 12:27 AM
455HOGT37's Avatar
455HOGT37
First mod I did - Radio Shack resistor across the plug... Disables "Big Brother" for less than a dollar. Come to think of it, it was at about three days of ownership that I did it too.
Old Mar 29, 2009 | 11:12 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
I’ve had my C6 for a year and have triggered the skip shift maybe twice, so to me it’s not an issue. If I were to disable it I’d use the Leres blown LED fuse method: http://xse.com/leres/z06/cags.html .
Old Mar 29, 2009 | 12:38 PM
yello9's Avatar
yello9
Does eliminating the skip shift raise a warranty issue?
Old Mar 29, 2009 | 12:52 PM
timd38's Avatar
timd38
I had one on my first 2006 and they still bought it back under the Lemon Law.
Old Mar 29, 2009 | 01:28 PM
goatts's Avatar
goatts
Actually the dealer recommended I install it when I bought the car. I did so the first week. Very annoying feature.
Old Mar 29, 2009 | 04:05 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Just remove the #10 fuse
Old Mar 29, 2009 | 04:47 PM
PDXPorkchop's Avatar
PDXPorkchop
I bought the part that they sell above at the Corvette store. It installs back on the trans.
I didn't know about the fuse option, that's a lot ez'er that jacking up the car and getting to the solenoid. Drove me nuts driving the car with that 1-4 shift only. Fisrt mod. I did.
Old Mar 29, 2009 | 05:06 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Someone is selling the fuse on eBay.
But personally, I would get someone to improve the factor tune. In HP Tuners you can easily to disable the CAGS along with a few minor tweaks such are more aggressive timing at cruise, lean out the PE, and less timing pulled out when intake temp increases.
Old Mar 29, 2009 | 05:09 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Check this out:
Old Mar 29, 2009 | 06:55 PM
Keencutter's Avatar
Keencutter
Originally Posted by BearZ06
This works great on my car.
If you just pull the fuse I think it will eventually throw a code. At least I believe that is correct.
Old Mar 30, 2009 | 05:46 PM
Markallamerican's Avatar
Markallamerican
Default LED Fuse
LED Fuse, One of the first things I did, Works perfect!
Old Mar 30, 2009 | 07:21 PM
BLACK 08's Avatar
BLACK 08
Exactly...Buy the Smart Fuse, blow it, and replace the stock fuse. Very simple and it works perfect.
Old Mar 30, 2009 | 08:34 PM
DonSet's Avatar
DonSet
Installed the blown Smart Glow Fuse (10a) and it works great. No codes, no skip shift.
To skip shift eliminator
Old Mar 31, 2009 | 06:11 PM
cadguymark's Avatar
cadguymark
Old Apr 1, 2009 | 10:51 PM
yello9's Avatar
yello9
I want to thank all who have answered. The reason that I'm late is that I have had some computer issues for the last day or two which were caused by me, not bill Gates. I do not have any shifting issues, however, since eliminating the Skip-shift on my Vette.
Please don't misunderstand. I am not doing any burnouts or power-shifting. I don't intend to, either. I have had enough of blowing engines, transmissions, clutches, and rear ends to last me a lifetime. I'm talking about '55 Chevy, "57 Chevy, '61 Pontiac Ventura, "64 ChevyII, and probably a few others that I'm not remembering right now.
I've been driving vehicles with manual transes since I was nine years old and still enjoy it.
I did notice a yellow Vette pictured next to one of the replies and for a second I was trying to figure out how the 'forum" got a picture of my car.
Hope to talk to you all soon and thanks again,
yello9
Old Apr 2, 2009 | 07:24 PM
yello9's Avatar
yello9
yello9
Shame on me. I forgot my '62 Corvette.
