Open Loop
Old Mar 31, 2009 | 05:34 PM
Boomer111's Avatar
Boomer111
Default Open Loop
I was experiencing some ( very little actually ) low rpm surging with the addition of the Vararam. The car was tuned also. Only way to get it to go away was to go Open Loop ( turning 02 sensors off )
What if any concerns should I have other than it will not pass sniffer until the sensors turned back on? I could probably live with the surge ( passenger can not feel it ) But it is smoother with Open Loop.
I was told not to worry but it is in my nature to question.
Thanks for any information
Old Mar 31, 2009 | 09:06 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Don't run open loop if you can help.
Take it back to your tuner. This should be easy to fix.
Old Apr 1, 2009 | 05:33 PM
Boomer111's Avatar
Boomer111
What are your reasons?
Old Apr 1, 2009 | 07:38 PM
Ragtop 99's Avatar
Ragtop 99
There is no reason for the car to be in open loop when warm with just a vararam. It is a sympton of a poor tune or installation error.
Old Apr 1, 2009 | 08:36 PM
Boomer111's Avatar
Boomer111
The car does have long tubes with cats too. Nothing else. The symptoms were present with just the Vararam. The Tubes were added a week later. Plug change also.
Old Apr 2, 2009 | 07:57 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Open Loop does not have any connection with the O2 sensors whatsoever. Closed loop is the stoichiometric loop feedback you are thinking of. No way to turn this off without ruining your car.
Closed Loop: O2 feedback loop designed to keep your calibration at 14.68:1 air fuel ratio (considered chemically correct total burn of gasoline)
Open Loop: Factory or tuner preset tables that have an Equivalency Ratio related to increasing fuel (which decreases the air-fuel ratio) to stave off pinging, and or detonation. Open Loop starts at approximately 48% throttle position (rpm dependent) to 100% throttle position. Open Loop air fuel ratios for the LS series Corvettes are typically 11.5:1 (fat)
Any surging you feel would be in Closed Loop and is related to turbulent airflow at the MAF sensor caused by ram air. Near impossible to tune out since it is a physical problem, not a tuning problem.
Our TRIC had this problem bigtime (1999-2000 RIP) and there was only one way to avoid it. Take off the intake or leave the laminar screen in the MAF. Unfortnately, the new style MAF has no laminar flow screens to help with the turbulence and buffeting.
Old Apr 2, 2009 | 08:54 PM
Boomer111's Avatar
Boomer111
Thanks for the correction. I will be able to live with the problem, really it is very minor. Passenger can not feel it. I was hoping to be able to have it tuned out. Oh well, if I get feed up later I'll heed your advice and pull the Vararam out.
Thanks again
Old Apr 2, 2009 | 09:38 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
The new probe MAF sensors are ultra sensitive, and Callaway has a baffle of some type that they are offering to keep surging down. All bottom breathers have this issue to some degree.
Maybe their solution would work for you. Check the other threads.
Old Apr 3, 2009 | 05:24 PM
Boomer111's Avatar
Boomer111
I have, thanks. Had the sensors turned back on. Humm not sure if I'll be able to live with this problem.
Old Apr 4, 2009 | 06:35 PM
Joe Lynch's Avatar
Joe Lynch
St. Jude Donor '09-'11
I have an '07 manual trans car with Vararam and headers and no surge. Runs fine in closed loop, but I tuned it myself. I don't remember having any surging problems at idle. Is yours an automatic?
Old Apr 4, 2009 | 09:13 PM
Boomer111's Avatar
Boomer111
No MN.6 Idle has not changed just at low rpm while cruising on surface streets.
Old Apr 19, 2009 | 07:12 AM
hymey's Avatar
hymey
open loop maf tuning is easy and it will eliminate surging. Its a good idea and something that is done commonly in Australia.
My car runs open loop SD (self tune)
Surging is more common with aftermarket intakes, Over the radiator style. I always disable Long term trims. Simply not required with e38 pcms. STFT is all I generally uses. And even then you don't need them if tune is correct.
cheers
To Open Loop
