What is needed to install LS7 exhaust manifold on LS3?
First of all, how difficult is this? Second, I've searched the forum pretty thoroughly but it's still not clear to me exactly what is needed and what is optional.
I have an LS3 with the NPP exhaust; I'd like to keep that exhaust if possible, or upgrade to the Billy Boat Fusion so I can still have dual modes.
I understand there is not just a manifold but cats and an h-pipe, and a special D-shaped gasket.
Also, I hear you need a 3" to 2.5" reducer. Does this need to be welded on, or is there a workaround? Seems like the welding would be restrictive if you ever decided to change/sell your exhaust.
Anything I'm missing?
My whole intent is to improve sound/power while keeping my warranty safe(er), but also keep myself open to upgrading parts later on without having to redo everything.
TIA.
TIA.
You will need the LS7 gaskets to match the manifolds and they will bolt right up. The rear oxygen sensor harness will need to have some tape unwrapped so they will reach the new locations. Extensions were not needed on my 08. The Z H pipe will bolt up to the manifolds and rear hanger without problems, but the connection to the NPP tailpipes will require some adapters. It might be as simple as adding some clamp on reducers to mate the two, but it may also require some trimming of the ends to fit also. I don't know what the length comparison is between the rear of the base and Z mid pipes.
TIA.
TIA.
Check out the link
http://forums.corvetteforum.com/c6-t...o-results.html
If you go with the Z06 manifolds and cats, you have a couple options of what comes next. (1) You can have a muffler shop modify your stock X pipe to mate up to the 3" cats. (2) You can use a Z06 X pipe and have a muffler shop fabricate a bit to mate exhaust to the X pipe, or (3) Get the Z06 exhaust and have all Z06 parts from tip to tail. I went with option 3 and the install was smooth. I don't think the Z06 exhaust fits, however, if your car is an automatic.
I'm using Walker Dynomax reducers on mine with clamps. Straight bolt on with no welding.
http://www.mustangmods.com/ims/u/1291/1870/279077.jpg
http://www.mustangmods.com/ims/u/1291/1870/279078.jpg
I cut my stock mid pipe about 8 inches in front of the hanger and I cut the H-pipe to the required length then I got 2 reducers made up at a exhaust shop the reducers need to be made so they fit over a 3 inch pipe on one end and on the other it needs to fit over a 2.5 inch pipe and I used band clamps and I have no leaks.
Check out the link
Check out the link
I was actually looking at those exact reducers. You still have to cut the H and mid-pipe, though, correct?
The C6 and Z06 H pipes are on different centerlines is why I cut mine so far up the Z06 H pipe. I wanted to minimize the angle going into the mufflers.
I just finished up putting them on my '08 tonight and it went suprisingly well. I also bought a Bassani catback for a Z06 (3") and everything bolted right up. You'll need the correct manifold gaskets, which I got from Gene Culley, and also the oval gaskets on the tailend of the manifold. That's it other than unwrapping the front O2 sensors a little so they reach the bungs which are a little further down than the stock locations.
The stock LS3 steel exhaust manifold gaskets work fine. Not sure why everyone is suggesting you need LS7 manifold gaskets.
I did the same thing, kept my NPP.I have am auto, so the muffler shop just cut and flared out the H-pipe to bolt up to the NPP. I like the way it sounds now. You will like it
I'd just got hip to this idea of putting Z06 exhaust on a base C6. I like the idea as it'll look stock and aid in, shall we say, the "visual inspection"!
My question is what hp difference is there in general between the base C6 exhaust and the Z06 exhaust (excluding the axle back - but everything from the engine to the axle back).
And what kind of prices have z06 owners been selling their take off exhaust for?
thx....!
thx....!
i did this a few years back on my 09 csc..
look under my name and there is an old post...hope it helps , it was a lotta work , but passes CA smog laws..
https://www.corvetteforum.com/forums...s7+install+ls3
