side mirror problem?
Old Apr 5, 2009 | 04:18 AM
snapalope86's Avatar
snapalope86
3rd Gear
Default side mirror problem?
here is my problem, have a 06 vette and the side mirrors keep reseting when i turn the car off so every time i get in i have to adjust them. anyone know what is the cause of this? thanks
Old Apr 9, 2009 | 01:05 AM
snapalope86
3rd Gear
Default hello
no one knows what is causing this? i think it might be a fuse but don't know which one it is if that is even the problem. help please.
Old Apr 9, 2009 | 08:40 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
If you have the memory option, adjust your mirrors, seats, wheel, etc... like you want them then on your door panel push and hold the "1" button for a few seconds until you hear a beep or two. This momorizes the settings. Sometimes they get out of whack for some people.
Old Apr 9, 2009 | 09:35 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Old Apr 9, 2009 | 09:53 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Rick, You must have the entire manual ready to cut and paste, your quick!
Old Apr 9, 2009 | 10:16 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I had this problem on my 05 (well known DBS car)
The only fix I found that worked was to set your mirrors in the position you wanted them to be while driving was in THE EXIT POSITION, that stopped them from moving when you get out. In plain English I set the mirrors to be in the same place while driving or in exit position!
It might take a couple times to set them till you get it right, but this worked for me till I got rid of the 05. (about 18 months)
I tried all the by the book procedures as I firmly believe in reading the manual.
Let me know if this works for you!
Old Apr 13, 2009 | 11:42 PM
snapalope86
3rd Gear
Default hello
it was the 1 and 2 button thing. thanks for the help guys!
To side mirror problem?
