c-6 lug nuts
Old Apr 6, 2009 | 10:13 PM
BOB SCHADLICK's Avatar
BOB SCHADLICK
Default c-6 lug nuts
Does anybody know of a protection cover for the lug nuts when removing tires with the 19MM socket?Yes i am ****!
Old Apr 6, 2009 | 10:40 PM
c6 batmobile's Avatar
c6 batmobile
Just F*** em up and buy a new set. If you put something over them I dont think you will be able to get the tire iron in there.
Mine are all jacked up and I just plan on buying a new set every so often. Its only 20-30 buck who cares.
Old Apr 6, 2009 | 10:42 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Plastic wrap.
San
Old Apr 6, 2009 | 11:31 PM
cadguymark's Avatar
cadguymark
always use a six point socket, not a tire iron or lug nut wrench
Old Apr 7, 2009 | 12:27 AM
c6 batmobile
Tire iron is six point.
Old Apr 7, 2009 | 01:09 AM
3 Z06ZR1's Avatar
3 Z06ZR1
lug socket with rubber inside to protect them, they sell them!
Old Apr 7, 2009 | 01:24 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I haven't seen rubber lined sockets, but have seen these before;
http://www.foxruntools.com/protectiv...socketset.aspx
San
Old Apr 7, 2009 | 11:34 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
I got the Harbor Freight item # 40035-7VGA sockets for $27.99.
Old Apr 7, 2009 | 12:53 PM
Vetter 1's Avatar
Vetter 1
I just purchased the Harbor Freight lug socket and have to say the plastic protection is only on outer part of the socket and inside at the point. Not on the sides of the lug socket. So, if you don't have a lug socket and need one buy it. Otherwise, I wouldn't spend the cash for it as it still marks up the lugs.
I would suggest their US General jack for $89 which is the lightest and cheapest to carry to the track.
Old Apr 7, 2009 | 01:31 PM
CMY SIX's Avatar
CMY SIX
mid america motor works has a 19mm socket with a hpde insert in it, also replacing your lugnut with real chrome plated, look for the word "HARDEND" these don't mar as easy
Old Apr 7, 2009 | 04:33 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Here ya go: http://forums.corvetteforum.com/c6-t...-for-lugs.html
Old Apr 7, 2009 | 10:45 PM
cadguymark's Avatar
cadguymark
and your point is?
take a good look at the socket, better yet measure, not all are the same size, some are quite loose, which is usually the case with a tire iron
Old Apr 8, 2009 | 06:23 AM
sea six's Avatar
sea six
These work great!
Old Apr 8, 2009 | 07:33 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
and your point is?
Also, you want a 19mm socket, not 3/4".
Old Apr 8, 2009 | 06:47 PM
TEXHAWK0's Avatar
TEXHAWK0
If you get a 6 point deep socket that fits well, you should not have a problem damaging the lugs. Also, always hand torque them. Do not use an impact.
To c-6 lug nuts
