2005 Battery Replacement Question
Old Apr 10, 2009 | 09:50 PM
als2052's Avatar
als2052
Default 2005 Battery Replacement Question
Will be replacing batt soon...
what functions will I have to reset?...
Is it worth installing battery bypass wiring sold in catalogs?
Appreciate your responses...
Old Apr 10, 2009 | 10:04 PM
VET4LES's Avatar
VET4LES
You will need to index the windows and that's it. It takes about 20 seconds. No need to install a bypass.
Old Apr 10, 2009 | 10:10 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Your windows may need to be re-indexed by doing the following:
Old Apr 10, 2009 | 10:25 PM
GotChrist?'s Avatar
GotChrist?
I just replaced mine a week ago. Ended up with a Optima red top. I did reindex the windows, but that was it. Everything else still seems hunky dory.
While you have the battery out, clean the cabin air filter and wipe the battery tray with 303. Use dielectric grease on the terminals along with the felt rings. They do work, though this car has had such good care taken of it, that the terminals still look new.
To 2005 Battery Replacement Question
