My 18 x 11" touches the control arm and needs to be jacked from the lower control arm to get the wheel off. While they never once touched in operation, I cant see a 17 x 11" being even in the realm of possibility.
In order to be possible it would need a 83 or 84mm offset and would require some shaving of the control arm to work.
My rear wheels are a 88mm offset at 11" wide.
The fronts will be ok at 62 to 68mm offsets.
Just curious, why is it that the 17x11 zr1's fit then?
