FOB Problems, HELP PLEASE!!!
I bought and installed a Braille lightweight battery that is rated for Daily use. (Maybe I should have gone with OEM type battery). It drained and ruined the 1st Braille after sitting for 4 or 5 days. 2nd Braille installed and was doing great. I took it to work and made a couple stops. I literally went into one of my doc's offices for 5 minutes,came out and it doesn't recognize my FOB. Alarm works, light in engine works, but no response from computer to recognize FOB. I put FOB in glove compartment spot with no luck. What am I to do?
I will disconnect battery and try to reset computer, but here's my other frickin dilema. I FAILED EMISSIONS! I have a 7 day sticker to log enough miles to pass (tech said failed cuz didn't have enough miles since battery was disconnected while I was getting the stupid pulley fixed at the dealership). Sorry so long winded. I am fed up with this POS. It looks great and is fast, but what a nightmare!
Any advice to fix would be appreciated. Thanks
Scott
Anyone else experience this? FOB working fine the whole day and then it decides not to work.
I wish they would just have a regular turn key ignition system. Good news is the battery is fine. Now I have to try to keep the FOB working for a couple hundred miles to log miles on the computer so that I can pass emission and buy my Illinois sticker with the frickin late fee. At least it is supposed to be 70 and sunny tomorrow. peace
Do you park in reverse?
The 'computer' does not reset - it is a myth.
To get rid of the 'not ready' condition(s):
A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes.
To perform an OBD-II Driving cycle do the following:
1. Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at start-up. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3. Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate. Let off the accelerator pedal. Do not shift or touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
I've got a thread titled "post-warranty wrap up" thats a few months old that details the dozen or so warranty-trips I made to the dealer... if you feel like consoling yourself. Lol.
The early C6's are laughably unreliable. Sucks, but what can you do...
Scott
buy a honda
